Ask an Expert Forum Opamp question.
  • Subscribers 324 subscribers
  • Views 1557 views
See a helpful answer?
Opamp question.
stiriac77
stiriac77 over 2 years ago
I'd like some guidelines on using opamps with a single 5V to 12V power source. From what I see in the documentation and WEB examples opamps require a double +/- power source. For small home automation projects this is not practical at all.
Would be grateful for pointing me to some tutorial or examples on the subject.
Thank you,
    shabaz over 2 years ago +6
    There's several guides on this. Googling for these terms will land you on two PDF documents: Single-Supply Op Amp Design Techniques and A Single-Supply Op-Amp Circuit Collection
  • dang74
    dang74 over 2 years ago +4
    A lot of op-amps require a negative rail because they can't produce 0V otherwise. Look at the VO, VOUT or Output Voltage Swing entry in the tables in the op-amp datasheet. For instance in the THS4031 data…
    genebren over 2 years ago in reply to shabaz +2
    These two are my go to references for all things in single-sided Op Amp designs!
    and
    • Vote Up +6 Vote Down
  • dang74
    A lot of op-amps require a negative rail because they can't produce 0V otherwise.  Look at the VO, VOUT or Output Voltage Swing entry in the tables in the op-amp datasheet.  For instance in the THS4031 data sheet you will see if you supply +/-5V at its rails the resulting maximum output swing is +/-3.4V.  Put another way you need 1.6V of headroom or margin on the rails in order to produce your desired voltage.  So if you were to connect this opamp's negative power rail to GND you probably couldn't produce a voltage any lower than +1.6V.
    There is good news though.  Some opamps are considered rail to rail.  A rail to rail op-amp doesn't require the margin described earlier in my example.  If you want to use a single supply in an opamp I would target rail to rail opamps.
    dougw over 2 years ago
    A few more resources:
    web.mit.edu/6.101/www/reference/op_amps_everyone.pdf
    ti.com/lit/an/snla140d/snla140d.pdf?ts=1689123779814&ref_url=https%253A%252F%252Fwww.google.com%252F
    ti.com/lit/an/snoa621c/snoa621c.pdf?ts=1689188197473&ref_url=https%253A%252F%252Fwww.google.com%252F
  • taifur
    taifur over 2 years ago
    Even you can use very common LM324
  • stiriac77
    Thank you all. Good information. Now I need to experiment.
    Any suggestions for a nice behaving OpAmp for a hobbyist?
