Ask an Expert Forum Help to Identify a wire to board(?) connector from an old arcade/pinball machine
  • Replies 13 replies
  • Subscribers 334 subscribers
  • Views 3337 views
  • connector
  • wire to board
  • board to board
  • pcb
See a helpful answer?
stanto
stanto over 3 years ago
pcb
A fellow member of Leeds Hackspace works on arcade and pinball machines and has asked for help in identifying these white connectors. Pin on header is 0.9mm wide by 0.66mm high, 5.5mm deep, with 2.54mm spacing. I was thinking something molex or jst, but I cannot find anything online with my limited skills.
Thanks!
    shabaz over 3 years ago in reply to stanto +2
    Looks like that's it... I ran the CAD model on the JST website to see the measurements, if your friend wishes to compare with calipers:
  • stanto
    stanto over 3 years ago in reply to shabaz +2
    Thanks, I'll pass this along!
    Jan Cumps over 3 years ago +1
    This may be the housing for the mating 25 pin connector: pinparts.co.uk/.../crimp-housing-0-dot-156-pitch-choose-size https://www.marcospecialties.com/pinball-parts/CF10025 and for the 4 pin one: www…
  • stanto
    stanto over 3 years ago in reply to phoenixcomm
    Ferrets are great aren't they?
  • stanto
    Sadly I don't have any closure for anyone on this as I haven't heard from the person as to how they've resolved it, however thank you for the input as it's appreciated Thumbsup
  • JWx
    JWx over 3 years ago in reply to phoenixcomm
    I was suspecting this is not a cat - cats, when illuminated by laser, usually try to catch the beam, and this one is taking evasive maneuvers - would probably fire smoke grenades if it had some Slight smile
