Ask an Expert Forum Help to Identify a wire to board(?) connector from an old arcade/pinball machine
  • Replies 13 replies
  • Subscribers 334 subscribers
  • Views 3311 views
  • connector
  • wire to board
  • board to board
  • pcb
See a helpful answer?
stanto
stanto over 3 years ago
pcb
A fellow member of Leeds Hackspace works on arcade and pinball machines and has asked for help in identifying these white connectors. Pin on header is 0.9mm wide by 0.66mm high, 5.5mm deep, with 2.54mm spacing. I was thinking something molex or jst, but I cannot find anything online with my limited skills.
Thanks!
    shabaz over 3 years ago in reply to stanto +2
    Looks like that's it... I ran the CAD model on the JST website to see the measurements, if your friend wishes to compare with calipers:
  • stanto
    stanto over 3 years ago in reply to shabaz +2
    Thanks, I'll pass this along!
    Jan Cumps over 3 years ago +1
    This may be the housing for the mating 25 pin connector: pinparts.co.uk/.../crimp-housing-0-dot-156-pitch-choose-size https://www.marcospecialties.com/pinball-parts/CF10025 and for the 4 pin one: www…
    I don't know the answer to that, but presumably then a special crimp tool would also be needed, for the mating connector. Maybe it's worth just soldering on a normal pin header to that, since it's 2.54 mm spaced. (if it doesn't matter that the header would extend out from the board a bit). It would be easy to strengthen with (say) Polydoh.
    and for the 4 pin one: www.moneymachines.com/.../
    dougw over 3 years ago
    It could be an obsolete Molex connector series....maybe these guys make a replacement...
    https://www.arcadepartsandrepair.com/store/pinball-kits-parts/pinball-parts/molex-28-56-crimp-pin-edge-connector-housing-me1005/
  • stanto
    stanto over 3 years ago in reply to Jan Cumps
    We're starting to think it's something like this:
    https://www.jst.co.uk/downloads/series/eNH_(10-11-30).pdf / https://www.jst.co.uk/productSeries.php?pid=179
    The board's from a Taito Continental Circus, the guy's wanting to maintain a bunch of them, "That connector with same pinout is used on a few Taito boards so I want a bench harness to test them rather than to mod a single board" (to address shabaz 's suggestion)
    Jan Cumps over 3 years ago in reply to stanto
    that looks very close indeed
  • anniel747
    anniel747 over 3 years ago
    Any way to measure the exact pitch?
  • stanto
    stanto over 3 years ago in reply to anniel747
    I don't believe they have access to tools to do so at the moment, but that's a good idea.
  • stanto
  • phoenixcomm
    phoenixcomm over 3 years ago in reply to stanto
     stanto your cat is ***!
    • Vote Up -1 Vote Down
