Ask an Expert Forum Inline Key Switch or Tamper Resistant control for mains devices?!
  • Replies 58 replies
  • Answers 2 answers
  • Subscribers 334 subscribers
  • Views 9285 views
See a helpful answer?
shabaz
shabaz over 3 years ago
For one reason or another (elderly relative), I'm looking for a way to prevent operation of a mains appliance (about 6A at 230V AC) unless, say, a key of some sort is inserted, to prevent them from using the appliance themselves. It doesn't need to be a high-security solution, it could simply be a plastic key for instance, that could be pushed in and rotated, to enable the appliance.
I don't wish to cut holes in the appliance, and really do want to do this inline with the mains wire.
Is there any existing product that could do this? If not, is there any suggestion that I could fit into a small plastic enclosure myself? I don't have access to a 3D printer, so it ideally needs to be a solution that I could make using conventional tools (electric drill, saw, etc).
One way I can think of, is to find some sort of enclosure where a rocker switch could be fitted recessed, and then have a small padlock such that it prevents the switch from operating. But it probably requires a custom box : ( Another way could be to have a Bluetooth controlled relay. I could design this, but I'd rather find an off-the-shelf solution.
I'm sure I can't be the only one wanting to do such a thing, but I'm having no luck googling for this.
Anyone come across anything that could help?
    shabaz over 2 years ago +6
    It arrived today, I'd say it is a 7/10 product.. it will certainly fit many plugs, but the build quality looks very average. The hinge looks fragile, although perhaps that's deceptive. I don't know. …
  • charlieo21
    charlieo21 over 3 years ago in reply to anniel747 +5 suggested
    Definitely the simplest and cheapest option, we have those in the lab, it works perfect to avoid someone use an equipment without authorization. Another option are those smart plugs that you can control…
  • beacon_dave
    beacon_dave over 3 years ago +5 suggested
    A long shackle padlock combined with a Lego Brick sized block with a hole in it (placed between the pins) could probably fit over a 13A plug top preventing it from being plugged into a socket. I don…
  • anniel747
    +1 anniel747 over 3 years ago
    [deleted]
  • beacon_dave
    0 beacon_dave over 3 years ago
    inline keylock switch in a small box ?
  • charlieo21
    0 charlieo21 over 3 years ago in reply to anniel747
    Another option are those smart plugs that you can control with any smart home assistant.
    https://www.amazon.com/WiFi-Smart-Plug-Outlets-Function/dp/B07Q1L6311/ref=asc_df_B07Q1L6311?tag=bingshoppinga-20&linkCode=df0&hvadid=80058242473102&hvnetw=o&hvqmt=e&hvbmt=be&hvdev=c&hvlocint=&hvlocphy=&hvtargid=pla-4583657824634358&th=1
    • Vote Up +5 Vote Down
    0 shabaz over 3 years ago in reply to anniel747
    This is great! And avoids having to mess around with wiring. I think I will go for this solution, unless anything better comes along! It looks perfect. I also like the inline keyswitch in a box idea that beacon_dave mentions, it may look a bit more discreet, but it's more effort of course, compared to this padlock over the mains plug!
    0 shabaz over 3 years ago in reply to charlieo21
    Nice-looking unit! There will for sure be UK versions similar to this. I'm definitely fine with glueing a mains plug permanently to such a product. It's an excellent solution.
  • beacon_dave
    I don't have the right padlock here but something like this with the padlock passing through a hole in the brick.
    We await the title of the next post "Outsmarted by an elderly relative"  Slight smile
  • anniel747
    0 anniel747 over 3 years ago in reply to shabaz
    Careful about those amp ratings.
  • Fred27
    0 Fred27 over 3 years ago
    If you do end up wanting a 3D printed solution then let me know. I'd be happy to print something and send it to you.
    0 shabaz over 3 years ago in reply to Fred27
    Hi Fred,
    Oh that's awesome, thank you for the support!
    I've ordered the Martindale product that anniel747  found, and will give it a shot! If it's no good then I think we should design a 3D solution since it could help many people! : )
    0 shabaz over 3 years ago in reply to beacon_dave
    LOL yes! : ) Also I'm hoping it doesn't vexate them to the extent to chop it off : )
