Ask an Expert Forum Sending emails through esp8266
  • Replies 8 replies
  • Subscribers 323 subscribers
  • Views 1610 views
See a helpful answer?
Tehkel
Tehkel over 2 years ago
Pls I am working on a school project, it is a smart delivery box that helps to keep hot foods meant for delivery warm.
The box has two sensors for checking temperature and monitor within the range of 135°F to 165°F. The box will have a smart lock system that generates a random pass word relays it to the microcontroller in this an Esp8266 and then the controller sends the password to the same or another email.
The receiver can now input the password to open the box when the order arrives
This is my first project and I don't know what to do.
    shabaz over 2 years ago +2
    Hi, I didn't really understand it all (it probably needs a diagram), but it seems you're looking for a way of sending e-mails using an ESP8266. There are plenty of resources on it online, e.g.: https…
  • colporteur
    colporteur over 2 years ago +2
    As has already been suggested you need to create a list of requirements. Make a list of all the things you want it to do. A diagram may help you explain what it is you are trying to do. The requirements…
    Jan Cumps over 2 years ago in reply to balajivan1995 +2
    I made an overview from MQTT to mail for a project14: Manage Arduino MKR WIFI 1010 Battery Life in the Cloud - AWS, Graphs and Alerts
    0 shabaz over 2 years ago
    There are plenty of resources on it online, e.g.: https://microcontrollerslab.com/esp8266-send-email-smtp-server-arduino-ide/
    Personally I think you need to re-think this, and move to an ESP32, or Pi Pico W. The ESP8266 is quite underpowered, I cannot see the reason for using it for a school project, when your life will be much easier with a more powerful device with a lot more modern code/tutorials online. The ESP8266 is pretty ancient.
    In any case, whatever you choose, it's a bit of a hack. It's not normally expected for a microcontroller to send e-mails. But there will be plenty of examples (perhaps hundreds!) online.
  • colporteur
    0 colporteur over 2 years ago
    As has already been suggested you need to create a list of requirements. Make a list of all the things you want it to do. A diagram may help you explain what it is you are trying to do. The requirements are what you build to. Include in your requirements any hardware requirements you can think of.
  • kmikemoo
    0 kmikemoo over 2 years ago
    I found these two in the Arduino IDE - the interface that you will use to program the ESP8266.  There are a lot of good (free) references on the internet, but nothing beats the example programs found in the Arduino IDE.
    Check out Arduino.cc for more help.
  • phoenixcomm
    0 phoenixcomm over 2 years ago
     Tehkel  One. I have owned an ISP phoenixcomm.net an email server or SMPT server can be HACKED and they're a major pain in the tush. instead of email etc. why not use low-power RFID (NF), alas, they don't all have this capability. So that will not work for everybody.
    Second way. send a text message to their phone.  Now this works but wait. Some older folks don't even have a mobile phone or know anything about text.
    BEST WAY off the TOP of the Head Instead of generating passwords (Breaks #2) use their phone number. easy peasy. ~~ C Harrison
  • balajivan1995
    0 balajivan1995 over 2 years ago
    Use AWS IoT core and publish messages to AWS endpoint.create a rule that will be triggered when your threshold is exceeded,create a SNS topic that will send mail to receiver, link that sns topic to rule.
  • colporteur
    0 colporteur over 2 years ago in reply to balajivan1995
    "Throw the horse out the window so hay!" I need to get out an email lexicon to translate those requirements. I had the same experience working with Perl programmers.
  • balajivan1995
    0 balajivan1995 over 2 years ago in reply to colporteur
    Sorry for that! Maybe one day I'll make a detailed and easily understandable post on how to use AWS IoT rule engine to send emails!
    0 Jan Cumps over 2 years ago in reply to balajivan1995
