Ask an Expert Forum Element 14 Audio Grade Capacitors
  • Replies 13 replies
  • Subscribers 334 subscribers
  • Views 2879 views
See a helpful answer?
Rocketeer
Rocketeer over 2 years ago
Hi All.
Hoping someone can advise.
I inherited some early vintage Japanese Loudspeakers needing rejuvenation.
Nothing fancy, just loudspeakers from small systems.
I think their worthwhile as they're from a bygone era.
They're fitted with various electrolytic capacitors maybe 40 - 50 years old.
Mostly single caps servicing the tweeters & ranging from 1.8µF to 3.3µF.
I don't want to over capitalize so thought electrolytic over film as they are not cutting edge hifi speakers.
Is there anything recommended from the element14 catalogue to replace the existing caps?
I'm open to both electrolytic & film depending on performance vs cost vs suitability to each application.
I haven't removed any of the caps for a test, but am going by their age & the general life of electrolytics.
cheers
Rocketeer (Rocky)
  • Gough Lui
    Gough Lui over 2 years ago +3
    To be truly honest, most of the Hi-Fi stuff is "snake oil" - differences in capacitors may cause subtle differences in audio but it's hard to say a given capacitor is necessary "sounding better" than another…
    michaelkellett over 2 years ago in reply to Rocketeer +1
    It just means that the value of capacitance is more tightly controlled (for a 5%) capacitor. In a cross over circuit a 20% error in capacitance could give you a 20% variation in turnover frequency. …
    Jan Cumps over 2 years ago in reply to Rocketeer +1
    I am an element14 and audiokarma community member :). Adore electronics and audio. A standard capacitor that meets the original specs will do. I am not usually suggesting to replace components if all…
  • anniel747
    0 anniel747 over 2 years ago in reply to Rocketeer
    Global aware farnell / newark / element14 store link
  • acdc90
    0 acdc90 over 2 years ago
    Replacing caps in audio amplifiers would have been a daily thing for me over the years
    i have a LCR meter but find the ESR kitset from silicon chip nicer
    in the amp of that age i would spray the controls with Deoxit D05
    much better than any CRC product.
    if it has a crackle replace the TO92 transisters. Usually its PNP ones that go noisy
    and any caps that are near a heat source like large resister or heat sink
    70s or 80s amps are so much easier to work on than modern things with HDMI
    you mite find a manual at acdcmanuals.com
  • Rocketeer
    0 Rocketeer over 2 years ago in reply to acdc90
    Thanks.
    Very worthwhile knowledge.
    Look for parts close to heat sources, especially visibly degraded parts, or other.
    I've been using CRC 2.26, but I'll definitely keep Deoxit D05 in mind when I run out.
