Ask an Expert Forum soft start resister value
  • Replies 15 replies
  • Subscribers 333 subscribers
  • Views 3261 views
See a helpful answer?
acdc90
acdc90 over 2 years ago
Hello I am repairing a DELTA VSD (varible speed drive )
model ASD-A2-1521-M
that had a dead IGBT module   FP50R06W2E3
And a melted blob where the soft start resister was
I think about (15mm long 6mm wide.wire wound)    3 or 4 watt  and 1/2 ohm
I no this is soft start because there is relay contacts that short out this resister usually seconds after power up
looking at the data sheet for   FP50R06W2E3  this resister is between pins  P and P1
this resister charges 1600uf cap
from P output from bridge
110v 3 phase input  estimate 275vdc to cap
My question is to resister  value ?
  • anniel747
    anniel747 over 2 years ago in reply to robogary +4
    robogary said: Upstream fusing
  • robogary
    robogary over 2 years ago in reply to dougw +2
    ( Im a VFD guy) the pre charge resistor is only in the circuit while the DC bus charges on first power up. Once the DC bus reaches a certain % of target, usually a 230VAC VFD has about a 350V DC bus, 460…
  • robogary
    robogary over 2 years ago in reply to anniel747 +2
    Possibly. Normal failure mode is short, at least for a short time. If stays short too long, either it melts down inside and explodes or the IGBT blows itself open. Upstream fusing is intended to limit…
  • anniel747
    0 anniel747 over 2 years ago in reply to robogary
    robogary said:
     I'm sorta amused the question asked about resistor value, but stated it is .5 ohms  3 or 4 watts.
    Also my thought
  • anniel747
    0 anniel747 over 2 years ago in reply to acdc90
    acdc90 said:
    dead IGBT module
    Dead doesn't mean shorted, it could also be blown open.
  • robogary
    0 robogary over 2 years ago in reply to anniel747
    Possibly. Normal failure mode is short, at least for a short time. If stays short too long, either it melts down inside and explodes or the IGBT blows itself open. Upstream fusing is intended to limit the energy on a ground/short/ other failure ......A blown pre charge resistor would tell me the bridge was probably shorted somewhere un;ess it was a cap that originally failed..
  • anniel747
    robogary said:
    Upstream fusing
  • acdc90
    0 acdc90 over 2 years ago in reply to anniel747
    yes the IGBT module was shorted
