Ask an Expert Forum I don't understand python venv
  • Replies 16 replies
  • Answers 4 answers
  • Subscribers 335 subscribers
  • Views 12745 views
  • raspberry pi 5
  • the environment is externally managed
  • raspberry pi 5 bookworm
  • python packages
  • pip install
  • venv
  • python3
See a helpful answer?
cstanton
cstanton over 3 years ago
This is going to be a growing pain for a lot of people that pick up the Raspberry Pi 5 with Bookworm, too.
A lot of guides and instructions say to do:
pip install <package>
Or
apt-get install python3-<package>
The 'problem' from a usability perspective now, is that when you try to do:
It complains at you with "this environment is externally managed" and to use a venv, and I don't understand them. It doesn't direct you on how to use a venv either.
I understand why we're doing it this way, so that we do not have a clash between operating system repository packages and the python pip installed packages.
Can someone explain to me how to use pip with a venv with an example package? I'm trying to find guides online and of course everyone has an opinion on how to do it three different ways but they also don't explain what exactly venv is doing or how to use it after installing the package with pip.
  • JWx
    JWx over 3 years ago +5 suggested
    Python suffers from multitude of interpreter and library versions - which can lead to the situation that one library cannot co-exist with another, because they - for example - are dependent on another…
    shabaz over 3 years ago +4 suggested
    I watched a training video on it a while back. It suggested the following: (1) First off, check you've got 'virtualenv' installed. That's easy to do by typing which virtualenv (2) If you don't have…
    michaelkellett over 3 years ago in reply to cstanton +3 suggested
    There's a comprehensive, but not perfect, description here. https://realpython.com/python-virtual-environments-a-primer/ which may help. MK
    0 shabaz over 3 years ago in reply to JWx
    Your example uses root, that's not advised (apart from for installing virtualenv itself, unless that is already installed).
  • JWx
    0 JWx over 3 years ago in reply to shabaz
    yes - old, bad habit... but - at the other hand - if user installs something using pip, it is installed on local account (not system-wide), so somewhat like a common  venv...
  • JWx
    0 JWx over 3 years ago in reply to JWx
    btw - original problem is only visible when installing from root account:
    user is not getting any warning:
    service@e14-panda:~$ pip install numpy
    Defaulting to user installation because normal site-packages is not writeable
    Collecting numpy
      Downloading numpy-1.26.1-cp310-cp310-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (18.2 MB)
         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 18.2/18.2 MB 3.8 MB/s eta 0:00:00
    Installing collected packages: numpy
      WARNING: The script f2py is installed in '/home/service/.local/bin' which is not on PATH.
      Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
    Successfully installed numpy-1.26.1
    only root gets - so examples are based on question's context:
    root@e14-panda:/home/service# pip install numpy
    Collecting numpy
      Using cached numpy-1.26.1-cp310-cp310-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (18.2 MB)
    WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: pip.pypa.io/.../venv
  • BigG
    0 BigG over 3 years ago
    Yes, I find this new requirement rather painful. If it's my device and the library download is just for that device then I just use the option "--break-system-packages".
    Otherwise, I think Python Poetry is worth considering instead of using venv.
    https://python-poetry.org/
  • cstanton
    0 cstanton over 3 years ago in reply to shabaz
    Hah, fortunately, I had not noticed and followed along as a standard user anyway.
  • cstanton
    Thanks for this step-by-step!
