Ask an Expert Forum sense rotation hall sensor (switch type)
  • Replies 15 replies
  • Subscribers 333 subscribers
  • Views 3181 views
See a helpful answer?
hazard
hazard over 2 years ago
hello everyone
I'm tryin to know a sense rotation of a wheel.
it is possible detect the sense rotation of a wheel with one magnet and and two sensor hall (switch type)?
if some one can help I will aprecciate the kindness.
BR
    dougw over 2 years ago +2
    The KMT32B-TD chip can accurately determine the angle and rotation of a magnetic field. datasheet I used one to control the steering angle of a robot: Sixth Sense - Magnetic Angle Sensor - GraffitiBot…
  • acdc90
    acdc90 over 2 years ago in reply to hazard +1
    Hello are you tring to get to get indication of speed or of direction or both ? are you going to put a magnet on the wheel or on the shaft. ? what would be the maximum RPM ? is this a temporary…
  • robogary
    robogary over 2 years ago +1
    Yes. You need to know decide on minimum speed you want to detect to decide if its running or stopped so you know how long to wait for a pulse. https://www.automation.com/en-us/articles/june-2021/how…
  • hazard
    0 hazard over 2 years ago
    you can tell me if i need check the time move between the sensores? or with the value of output sensor?
  • acdc90
    0 acdc90 over 2 years ago in reply to hazard
    Hello
    is this a temporary build or long time  ?
    is it covered or in a wet environment ?
  • robogary
    0 robogary over 2 years ago
    https://www.automation.com/en-us/articles/june-2021/how-encoders-provide-motor-speed-position-control
    When a gearbox is used, its better to detect the motor shaft position and speed because you get more  pulses on the high rpm side of a gearbox or pulley.
  • hazard
    0 hazard over 2 years ago in reply to acdc90
    speed, RPM and grequency.
    yes, put one magnet on the wheel
    100Hz max freq.
    longe time build
    covered environment.
    thanks
  • acdc90
    do you what an off the shelf sensor that just screws to what ever frame there is and has 3 wires +v end and out put
    or 2 wires and that needs a pull up resister to +v
    or is this on a budget where you want a TO92 package on some vero board
    is there already some dc v near by ?
    what out put of sensor is required eg 0 to 5v
    how stable is the environment for screwing a sensor to
    is the wheel only going 1 direction
  • hazard
    the sensor are pull push output, and they works on 5v. the wheel go to CW and CCW.
  • hazard
    0 hazard over 2 years ago in reply to robogary
    the sytem is basic like this operation: the wheel rotate CW maybe 5 ou 6 times, than return to original position on CCW.
    the movement have around 25hz , some time 10, other 15 or 25.
    the time is between this values.
  • acdc90
    if you want to no which direction the wheel is turning who will need 2 sensors
  • acdc90
    are you trying to count the number of turns from center or home position
  • robogary
    0 robogary over 2 years ago in reply to hazard
    25 revolutions per second ? 40 msec a rev - with only 5 or 6 samples will not likely provide a good stable speed feedback calculation. You can count the pulses, but stop has to be really hard to avoid overshoot and miss.
