Ask an Expert Forum help on finding a replacement part, rotary potentiometer
  • Replies 7 replies
  • Subscribers 325 subscribers
  • Views 1630 views
See a helpful answer?
AndreaM
AndreaM over 2 years ago
Hello everyoneimage, i'm quite new here and don’t have much knowledge in the field of fiimagending parts with part numbers and so on.
I'm searching this potentiometer, found on the side the Alps logo so basically i've searched for every part producted by them, but i've only found similar ones with 3 pin, mine has 5..
Already bought this one thinkin i've hit the jackpot but again 3 pin https://it.farnell.com/alps/rk09k1110bsc/potentiometer-10ka/dp/1191736 so i really don't know how to move
If someone can direct me to a part that can be used to replace this that would be greatly appreciated.
  • anniel747
    anniel747 over 2 years ago +6
    Deleted
  • AndreaM
    AndreaM over 2 years ago in reply to shabaz +3
    The 7 pin things has drove me crazy, spent hours searching everywhere, thank you very much for the quick reply
  • AndreaM
    AndreaM over 2 years ago in reply to anniel747 +1
    thank you! is it! you have no idea how much time i've spent searching, i owe you one
    0 dougw over 2 years ago
    Presumably the extra 2 pins are a switch?
    CTS makes similar pots with 5 pins, but theirs have 3 pins on the shaft side and 2 pins in the rear.
    0 shabaz over 2 years ago
    I don't think you're going to find an exact replacement on the Farnell site. It's a really low-cost consumer-grade part that Alps may have directly supplied to TV/radio manufacturers etc in the past. Anyway, there are many variants of it available in China. The one in the screenshot below (from AliExpress) might fit, but you need to measure and verify.
    EDIT: I just noticed your potentiometer has 7 pins (i.e. 5 pins plus 2 mounting pins. That makes it harder.. I cannot see that on AliExpress.
  • anniel747
    0 anniel747 over 2 years ago
    [deleted]
    • Vote Up +6 Vote Down
  • AndreaM
    0 AndreaM over 2 years ago in reply to anniel747
  • AndreaM
    0 AndreaM over 2 years ago in reply to dougw
    Idk, it should be a volume potentiometer, but i think i've found it, thank you!
  • AndreaM
    0 AndreaM over 2 years ago in reply to shabaz
    0 dougw over 2 years ago in reply to anniel747
    Good work finding this part...
