Ask an Expert Forum ch32v307
  • Subscribers 334 subscribers
  • Views 1023 views
See a helpful answer?
ch32v307
luciano1949
luciano1949 over 2 years ago
I'm tryng to use a board mounting a RISC-V ch32v307 in developement ambient MounRiver Community.
You can find examples in https://github.com/openwch/ch32v307  and microcontroller RM in https://www.wch-ic.com/downloads/CH32FV2x_V3xRM_PDF.html
Many thank for 120 project examples , but I prefer a GOOD  reference manual.
The example  I try ,in EVT\EXAM\ADC\Internal_Temperature, use the internal temperature sensor  I THINK WITH CALIBRATION.
In fact the system call a Get_CalibrationValue().
Has somebody an Idea what the fonction is doing? there is a reference manual where understand this code?
 * @fn      Get_CalibrationValue
 * @brief   Get ADCx Calibration Value.
 * @param   ADCx - where x can be 1 or 2 to select the ADC peripheral.
 * @return  CalibrationValue
int16_t Get_CalibrationValue(ADC_TypeDef *ADCx)
    __IO uint8_t  i, j;
    uint16_t      buf[10];
    __IO uint16_t t;
    for(i = 0; i < 10; i++)
        ADC_ResetCalibration(ADCx);
        while(ADC_GetResetCalibrationStatus(ADCx))
        ADC_StartCalibration(ADCx);
        while(ADC_GetCalibrationStatus(ADCx))
        buf[i] = ADCx->RDATAR;
        for(j = 0; j < 9; j++)
            if(buf[j] > buf[j + 1])
                t = buf[j];
                buf[j] = buf[j + 1];
                buf[j + 1] = t;
    t = 0;
    for(i = 0; i < 6; i++)
        t += buf[i + 2];
    t = (t / 6) + ((t % 6) / 3);
    return (int16_t)(2048 - (int16_t)t);
  • koudelad
    0 koudelad over 2 years ago
    I don't have the reference manual and haven't searched for any, but the C code does the following:
    1. The function initializes variables and an array to store some ADC readings in buf[10].
    2. It then enters a loop where it performs ADC calibration and reads the ADC value 10 times. The readings are stored in the buf array.
    3. After obtaining the ADC readings, the function sorts the buf array in ascending order using a simple bubble sort algorithm.
    4. The function then calculates the average of the middle 6 values in the sorted buf array (doesn't count with the first and last two values).
    5. Finally, it calculates the calibration value by subtracting the average from 2048 and returns the result as a 16-bit signed integer (int16_t). This calibrated value is likely used for accurate ADC conversions in subsequent measurements.
    BTW I used a web search to find the function name and got results which indicate that similar API is used in STM32 HAL libraries. Maybe someone got inspired in this.
