Ask an Expert Forum ohms law
  • Replies 17 replies
  • Subscribers 331 subscribers
  • Views 3619 views
  • ask_an_expert
See a helpful answer?
ohms law
Akans
Akans over 2 years ago
how did i use ohms low to choose a resistor for my circuit when the current of the voltage is unknown. like i have a 10 volt resistor and i need 5volt out from the 10volt what will i do to get the current so that i can use it to divide the voltage to get my resistor for the circuit as ohms low states
    shabaz over 2 years ago +5
    You should get a basic multimeter, and a small pack of resistors, and just try it. Take measurements, observe if anything gets hot, and compare with your expectations. What's the worst that will happen…
  • JWx
    JWx over 2 years ago in reply to Akans +4
    for driving a LED you need three values: power supply voltage, diode forward voltage and diode current. Diode current can usually be in the range of about 2-20mA Diode voltage depend on the color and…
    shabaz over 2 years ago in reply to shabaz +4
    I decided to eat own dogfood and check out the link.. The Learning Circuit is excellent, part 5 discusses the LED example. Ohm's Law with Breadboard Circuits -- The Learning Circuit 05 https://youtu…
    0 dougw over 2 years ago in reply to Akans
    What does this motor do? What is the current or power rating for the motor? Most 12V motors can take 18V for a short time if you just need to test something, but it may depend on how heavily the motor is loaded.
  • phoenixcomm
    0 phoenixcomm over 2 years ago
    Your question is ambiguous Akans  Basically, any two resistors in a series of the same value will do, and take the 5v from the center,  BUT you need to know what the output will drive! led ok 20ma, you could use 1/4 what resistors, QUESTION:  "i have a 10-volt resistor"  1. I have no idea what a 10-volt resistor is. 2 did you mean output??  Please restate the question properly.
    and the other question why do you want to use a voltage divider with resistors, better way to it would to use a 3-lead regulator. or better use aa DC-Buck Reg this one is from eBay! image
    0 shabaz over 2 years ago in reply to shabaz
    Note there is a typo on one of the images part-way through the video, where the value should be 20mA, but the text shows 2mA. Aside from that I think it is all fine!
    The Learning Circuit was excellent, and there are 98 episodes! I wish element14 would bring it back with the same host (Karen) for a Learning Circuit series 2. Anyway, the videos there will help a lot I think (but also supplement your learning with a book or two, since it's good to have a couple of sources, to solidify your knowledge by reading things re-stated in different ways).
  • colporteur
    0 colporteur over 2 years ago
    Is it possible to provide a drawing (i.e. schematic) of what you are trying to accomplish.
    Some of the description is ambiguous ((i.e. I have a 10 volt resistor), making it difficult to understand what you are trying to accomplish. A photo of a pencil drawing would work if you are not familiar with graphic software.
    In reading the post, you had an optional question with a motor. Sketch that out also so we can analyze and provide help.
  • beacon_dave
    0 beacon_dave over 2 years ago in reply to shabaz
    The OP had already posted their first question about Ohms Law there. Slight smile
    +1  Definitely.
  • cstanton
    0 cstanton over 2 years ago in reply to shabaz
    We loved the learning circuit, and the name is pretty good too, though it ran its course and we transitioned to DC to Daylight.
    0 shabaz over 2 years ago in reply to cstanton
    Interesting, I did not know that was the successor. Looking forward to checking it out!
