Ask an Expert Forum ohms law
  • Replies 17 replies
  • Subscribers 331 subscribers
  • Views 3556 views
  • ask_an_expert
See a helpful answer?
ohms law
Akans
Akans over 2 years ago
how did i use ohms low to choose a resistor for my circuit when the current of the voltage is unknown. like i have a 10 volt resistor and i need 5volt out from the 10volt what will i do to get the current so that i can use it to divide the voltage to get my resistor for the circuit as ohms low states
    shabaz over 2 years ago +5
    You should get a basic multimeter, and a small pack of resistors, and just try it. Take measurements, observe if anything gets hot, and compare with your expectations. What's the worst that will happen…
  • JWx
    JWx over 2 years ago in reply to Akans +4
    for driving a LED you need three values: power supply voltage, diode forward voltage and diode current. Diode current can usually be in the range of about 2-20mA Diode voltage depend on the color and…
    shabaz over 2 years ago in reply to shabaz +4
    I decided to eat own dogfood and check out the link.. The Learning Circuit is excellent, part 5 discusses the LED example. Ohm's Law with Breadboard Circuits -- The Learning Circuit 05 https://youtu…
  • baldengineer
    0 baldengineer over 2 years ago
    What are you trying to accomplish? It sounds like you need a voltage regulator, not a voltage divider.
  • JWx
    0 JWx over 2 years ago
    do you want do create voltage divider to get 5V  from 10V?  What level of current are you going to draw? As baldengineer have stated, using divider would be really wasteful - regulator would be better choice
  • JWx
    0 JWx over 2 years ago in reply to JWx
    using circuit as above, with two resistors of the same value, you can get half of voltage in the middle point - if you draw only a small current (if you draw more, voltage across R2 drops)
  • Akans
    0 Akans over 2 years ago in reply to JWx
    what i am trying to say is how to choose a resistor for a led all tutorial i have watch seams they get their current from datasheet and they use ohms low to work out and get the suitable voltage for the led and i have been founding it difficult choose a resistor for my circuit because using ohms low is voltage divide by current and i am using batter so what should i do
  • javagoza
    0 javagoza over 2 years ago in reply to JWx
    This is a community created online calculator.
    Voltage divider calculator for real E-series resistors (douxchamps.net)
  • JWx
    0 JWx over 2 years ago in reply to Akans
    Diode voltage depend on the color and is standard for that color - for example, yellow LED has forward voltage of about 2.1V
    then, all the remaining voltage should be across the resistor - so (for example, using 9V battery and 5mA)
    9V - 2.1V (diode forward voltage) = 6.9V (voltage drop across resistor)
    6.9V/5mA = 1380 Ohm
    this is not a standard value, but you can use - for example - 1.3kOhm (1300Ohm)
  • Akans
    what about if i want to drive a 12volt motor and i have a voltage supply to be 18v what should i do
    0 shabaz over 2 years ago
    You should get a basic multimeter, and a small pack of resistors, and just try it. Take measurements, observe if anything gets hot, and compare with your expectations. What's the worst that will happen? Combined with some reading, I guarantee you'll learn more that way than the mistakes you make.
    Ohm's law is fundamental, and will be covered in many books, but there are excellent recommendations here:
     I Want to Do Electronics!  Where do I start?
    • Vote Up +5 Vote Down
  • JWx
    install a voltage regulator - switching one if possible to limit power loss.
    Motor has a different characteristics - it consumes different current depending on the load. You can probably limit the current using resistor but it would be wasteful - if you calculate the resistor for idle current, any load increase would increase voltage across resistor, decreasing voltage across motor and limiting power. And if you calculate resistor for loaded motor, you will get overvoltage when motor is idle.
    Anyway - if you can tell what current   will be drawn during operation (for example - steady load), the method is the same - all the excess voltage should be across resistor.
    for example - motor consumes 2A during operation, and voltage difference is 18V-12V = 6V
    6V/2A = 3 Ohm
    and power dissipated would be 6V*2A = 12W
    and of course - if motor is stalled, most of the input voltage would be across the resistor, resulting in 18V * 18V/3Ohm = 108W of power
    0 dougw over 2 years ago
    The question is not clear to me.
    Assuming you have a resistor with 10 volts, connecting an identical resistor from that resistor to ground will drop the voltage to 5 volts.
