Ask an Expert Forum cga to vga converter uPython
  • Replies 46 replies
  • Subscribers 332 subscribers
  • Views 8306 views
  • python
  • raspberry pico
  • ask_an_expert
  • microcontrollers
  • teensy
  • vga
See a helpful answer?
rlaci
rlaci over 2 years ago
Hi
im new to uPython and needing some help with fast interrupts, port handling, reading into controller, handling the big amount of data and speed
my main aim is to get it working on raspberry pico, as colors 1bit resolution is enought as its an industrial equiment with RGBHV 15.6khz input(output from the machine) need to transfer it to 31khz VGA standard output for an lcd monitor
any help welcome
thanks!
    shabaz over 2 years ago +3
    There's a website listing monitors that support your resolution: http://15khz.wikidot.com/ I think it's far more likely that you'll be able to source a monitor if you search long enough on eBay, than…
  • beacon_dave
    beacon_dave over 2 years ago in reply to shabaz +3
    There is a PIO based implementation of a VGA driver discussed here if anyone is interested: https://www.youtube.com/watch?v=ZXMdZGQzrWg
    michaelkellett over 2 years ago in reply to rlaci +3
    It's very, very difficult. You need to delve quite deeply into the data sheets. The things to look for are the IO toggle rate, maximum clock rate of internal RAM, and maybe some benchmarks of complete…
    0 shabaz over 2 years ago in reply to rlaci
    Async read of an entire line could certainly work, with the async line capture initially triggered from the sync  signal. Anyway, it's likely time to spend a week or two trying out some hardware (it doesn't cost a lot), to investigate what limits you will hit, and what you're comfortable coding with, to rule things in or out, because it seems that's a significant grey area currently, because expectations (Python, Arduino etc) are not aligned with what may be feasible (I feel) but it also depends on what you will be OK coding for.
  • beacon_dave
    0 beacon_dave over 2 years ago in reply to shabaz
    I recall that Ben Heck did a project with FPGA to convert to VGA a while back. Might have been the Giant Game Boy episode.
    0 shabaz over 2 years ago in reply to beacon_dave
    That rings a bell. I recall I wanted to do a similar thing for a Game Gear I had lying around, but never had the time for it : (
  • beacon_dave
    0 beacon_dave over 2 years ago in reply to rlaci
    rlaci said:
    is there any arduino like reprogrammable fpga board for learning?
    For a while, Arduino sold the MKR Vidor 4000 which was a SAMD21 based microcontroller board with an Intel Cyclone 10 FPGA on it. Unfortunately they discontinued it.
    The Lattice Semiconductor iCEstick is back in stock (iCE40 FPGA) and might be worth a look as a starter board. It's a bit more lightweight when it comes to the software side and there is also an open source toolchain available for it.
    Shawn Hymel uses one in Digikey's: Introduction to FPGA series
    https://www.youtube.com/watch?v=lLg1AgA2Xoo&list=PLEBQazB0HUyT1WmMONxRZn9NmQ_9CIKhb
    rlaci said:
    what kind of programming languages FPGA-s using to program them and what is the whole approach to make it work?
    Mainly Verilog or VHDL.
    Whitney Knitter: 2-Minute FPGAs
    /technologies/fpga-group/w/documents/5399/summer-of-fpgas-2-minute-fpgas-with-whitney-knitter
  • beacon_dave
    I think Ben did two shows with FPGA.
    Ben Heck’s Giant Game Boy Episode -- Episode 225
    /challenges-projects/element14-presents/benheck/ben-heck-exclusive/w/documents/1370/ben-heck-s-giant-game-boy-episode----episode-225
    https://github.com/thebenheckshow/225-tbhs-Giant-Game-Boy/tree/master/DE0_GameBoy_DMG-01_VGA-master/Software
    Ben Heck's FPGA LCD Driver Hack Episode -- Episode 169
    /challenges-projects/element14-presents/benheck/ben-heck-exclusive/w/documents/18694/ben-heck-s-fpga-lcd-driver-hack-episode----episode-169
    https://github.com/thebenheckshow/169-tbhs-FPGA-LCD-Driver-Hack
    Amazing how expensive the iCEstick has become. I got it for about £25 a couple of years ago. Now it is >£120. Fortunately easy to replicate, since it's just a TQFP chip.
  • rlaci
    0 rlaci over 2 years ago in reply to beacon_dave
    looks interesting and did not find by my own
  • beacon_dave
    Ouch! I must have got mine just in time then. You were lucky to get then a couple of years ago as they were very difficult to get hold of due to the supply chain issues.
    Something like the Olimex board might be a cheaper alternative these days:
    https://www.olimex.com/Products/FPGA/iCE40/
    0 michaelkellett over 2 years ago in reply to beacon_dave
    I was going to suggest this:
    https://www.aliexpress.com/item/1005006165197426.html
    But the learning curve with the Olimex and iCE40 will be easier.
  • rlaci
    how the speed of an fpga is measured, compared, what should i look for if selecting for a project?
