Ask an Expert Forum Mini USB signal measurement.
  • Subscribers 328 subscribers
  • Views 1224 views
See a helpful answer?
Yashaselement14
Yashaselement14 over 2 years ago
In our product we are using Mini USB for flashing purpose. Speed is 480Mbits/s. I'm using Lecroy PP020 500MHz for measuring the D+ and D- signals in USB. But the ringing is High, I'm not able to get a more defined Square wave to conclude. I have given shortest Ground for probe as well. what is the reason for High Ringing in Output.
    shabaz over 2 years ago +6
    Hi, Your probe is intrusive. It still has inductance (even with your shortest ground) and capacitance, so has loading, and will also cause an impedance mismatch. It's no surprise you won't see an accurate…
  • baldengineer
    baldengineer over 2 years ago +2
    In addition to the loading of the passive probe, it doesn't have enough bandwidth. Using a 500 MHz signal to look at an (effectively) 480 MHz signal means seeing only the fundamental sine wave. The edges…
  • jc2048
    jc2048 over 2 years ago in reply to baldengineer +1
    Isn't alternate ones and zeros at 480Mbps a fundamental of 240MHz?
    0 shabaz over 2 years ago
    Your probe is intrusive. It still has inductance (even with your shortest ground) and capacitance, so has loading, and will also cause an impedance mismatch. It's no surprise you won't see an accurate representation of the signal. What's the purpose? If you really wish to accurately see a 'shape' on an oscilloscope for some certification procedure or similar, you'll need a proper test fixture for this, e.g. TDSUSBF (which costs several $k).
    If your purpose is to troubleshoot a fault, you might not need to closely observe the signal integrity, your issue might be elsewhere. Or you could use visual inspection to see what you've got wrong (e.g. extremely badly laid out PCB).
    • Vote Up +6 Vote Down
  • baldengineer
    0 baldengineer over 2 years ago
    In addition to the loading of the passive probe, it doesn't have enough bandwidth. Using a 500 MHz signal to look at an (effectively) 480 MHz signal means seeing only the fundamental sine wave. The edges of those signals contain significantly higher frequency content.
    For the 3rd harmonic, you need at least 1.5 GHz (both scope and probe.)
    And, I believe the USB Compliance Spec requires 2.5 GHz for High-Speed devices.
    For High-Speed devices (and faster) you need active probes.
  • jc2048
    0 jc2048 over 2 years ago in reply to baldengineer
  • jc2048
    According to the manual, the probe you're using has HF compensation, not just the more usual LF compensation. Did you make sure that it was properly adjusted before you started?
  • Yashaselement14
    0 Yashaselement14 over 2 years ago in reply to jc2048
    Yes, Both HF2 and HF1 compensation was done.
  • baldengineer
    0 baldengineer over 2 years ago in reply to jc2048
    *facepalm*. Yes. You are right! The fundamental is 1/2.
    But. Even at 240 MHz, the 3rd harmonic is around 720 MHz. So, 500 MHz still isn't enough bandwidth to reconstruct a square wave.
