Ask an Expert Forum First power bank build (project)
  • Subscribers 324 subscribers
  • Views 753 views
See a helpful answer?
Rowbow68
Rowbow68 over 2 years ago
Hello! I’m about to start a diy power bank build from a kit I ordered from eBay it’s basically a box with a BMS,lithium battery case, 18650 welding brackets, and nickel strips. I was looking for spare parts to add to the build and ran across an old mycharge power bank the ones with the wall  plug built in, two charging cables one usb cable and an apple lightning charger cable. My question is, is it possible to integrate the module and the AC wall plug into the power bank and if anyone can draw a schematic or know some place where I can find something similar to help me with putting the two together!
    shabaz over 2 years ago +2
    Hi, It's too high a risk to DIY it based on eBay parts, let alone even if you'd sourced everything from a known distributor. My advice as an engineer is don't do it. There's a high chance of fire if…
    0 shabaz over 2 years ago
    It's too high a risk to DIY it based on eBay parts, let alone even if you'd sourced everything from a known distributor. My advice as an engineer is don't do it. There's a high chance of fire if you DIY this. This is not the sort of project to learn on.
    If it kills someone and you constructed it, you'll be liable, and morally, it would be your fault just as much as the eBay seller's.
