Ask an Expert Forum Audio Power Transistors - Buying in Bulk
  • Replies 18 replies
  • Subscribers 333 subscribers
  • Views 3169 views
See a helpful answer?
dank123
dank123 over 2 years ago
Hi All,
Does anyone have a solid opinion on the quality of Multicomp Pro MJ15003 and MJ15004 power transistors (Newark# 76AH5818 and 76AH5819)? I want to stock up on these parts as I use them quite a bit and the Multicomp Pro ones come in at about half the cost of the other name brand devices. I use these parts for vintage audio amplifier repair and the occassional amp build from scratch. Not exactly critical applications, but I'd like to get some assurance that they are at least worth the money. Otherwise, I may as well just spend the extra and get ONSEMI. Has anyone tested this Multicomp Pro transistors to see what conditions they fail under as compared to the ONSEMI ones?
    michaelkellett over 2 years ago +4
    Looking at the data sheets for the parts I would sy that there are definite causes for concern: The features section of the Multicomp data sheet seems to be for a different part. Multicomp features…
    Jan Cumps over 2 years ago in reply to michaelkellett +3
    michaelkellett said: almost all your customers would rather have the Onsemi parts. "No one gets fired for buying IBM" was the IT equivalent for that.
    shabaz over 2 years ago in reply to anniel747 +3
    "Why would you think it's a fake?" Because your photo was taken from a counterfeit transistor web-page that explains it in black-and-white: As you can see from the red highlighted text, the purchaser…
  • anniel747
    0 anniel747 over 2 years ago in reply to shabaz
    [deleted]
    0 Jan Cumps over 2 years ago in reply to michaelkellett
    0 shabaz over 2 years ago in reply to anniel747
    As you can see from the red highlighted text, the purchaser was caught in a bait-and-switch.
    That's very different from the Multicomp part, which will, in all likelihood, meet the (limited) datasheet spec that it is supplied with.
    "Many parts sold at Farnell/Newark come from china."
    Many fake parts come from China. But the OP is specifically discussing parts from a distributor that will have processes in place to prevent bait-and-switch.
    0 shabaz over 2 years ago in reply to michaelkellett
    A friend asked for a Bluetooth adapter.. even though off-the-shelf ones only cost £20 or so, I built him a custom one (off-the-shelf Bluetooth board), and even non-technical people want to actually know their product isn't being skimped on cost (this one cost them £100 in parts) and proper external antenna since no-one wants poor signal quality. The filter caps are 105 deg C since this is going to be fitted in a car and the longer life will help. The audio connectors are expensive these days, but I wouldn't feel comfortable fitting the cheaper plugs that become a loose fit over time. The screened cable is really high quality (StarQuad cable originally intended for mics).
    The black stuff providing the strain-relief inside the case, is Polydoh! : ) Surprisingly effective.
    Next time I win a shopping cart, I'm going to add a few of these. Not because I need some, but for the lab experience.
  • dank123
    0 dank123 over 2 years ago in reply to michaelkellett
    I agree.
    The ONSemi parts are only slightly more expensive than the Multicomp on Newark when you buy 10 pieces. May as well just get ONsemi.
    One practical way to test the Multicomp devices would be to take a stereo amplifier and replace the transistors in one of the two channels, then run it for a while to see what happens. Or, run it with a dummy load connected and stress it out.
    There is a pretty good diversity of opinions on here and I think I have all the info I need. Thanks to everyone who chimed in.
    0 Jan Cumps over 2 years ago in reply to dank123
    The dummy load vs specs approach would be the safest one.
    But do we know if the original amplifier would actually have survived a bench test with a dummy load vs specs?
    0 michaelkellett over 2 years ago in reply to dank123
    Places where a device with a more restricted SOA might fail are usually not exercised with a dummy resistive load.
    But if you try more difficult loads you are into the region of Jan's conundrum where you don't know if the full spec part would have done better.
    So to be sure that the parts of equivalent robustness  you would need to test both types to failure - which might be fun but rather time consuming and expensive.
    Comparing both channels with different parts is a reasonable compromise but most audio amplifiers are not that well cooled so you may be mainly comparing the susceptibility to overheating - which in turn will be influenced by how well the parts are contacting the heatsink etc. etc.
    Please let us know how you get on - and if any parts fail in interesting ways !
