Ask an Expert Forum 60S019P-301N-B1
  • Replies 17 replies
  • Subscribers 331 subscribers
  • Views 2872 views
See a helpful answer?
60S019P-301N-B1
Ping_
Ping_ over 2 years ago
Supplier said it ordered from element14, but the goods don't have dielectric pad on contacts, is it ok to use?
  • anniel747
    anniel747 over 2 years ago +1
    Deleted
  • Ping_
    Ping_ over 2 years ago in reply to anniel747 +1
    yes, supplier told this
  • anniel747
    +1 anniel747 over 2 years ago
    [deleted]
  • aswinvenu
    +1 aswinvenu over 2 years ago
    You meant that black dielectric pad is missing in the connector?
    Do you have a picture of the connector you received?
    +1 dougw over 2 years ago
    element14 is not a sales outlet - they don't sell products.
    Connectors always have a dielectric between contacts, whether it looks like we expect or not.
    The dielectric between contacts is only one aspect of high voltage rating. Contacts this close together cannot be exposed to air, if you expect 500 volts between contacts - the air would breakdown and arc. You would need a conformal coating to prevent arcing.
    The electronics associated with these connectors would need to be pretty special if they are expected to survive 500 volts.
    • Vote Up -1 Vote Down
  • Ping_
    0 Ping_ over 2 years ago in reply to aswinvenu
    Please check the pic   image
  • Ping_
    0 Ping_ over 2 years ago in reply to dougw
    thank you
  • aswinvenu
    +1 aswinvenu over 2 years ago in reply to Ping_
    I think the connectors will work. These are vertically mounted connectors. Don't push the connector all the way into the PCB ( Chances of shorting between pins ), leave a small gap.
    What I can see is that the black part missing is acting like a spacer. If it's a production ready design facing costumers then I would recommend don't use these connectors, If it's some kinda hobby project use it carefully.
  • Ping_
    Will not use it cuz we are not sure if it's brand new parts.
  • Ping_
    Thank you so much
  • Ping_
    0 Ping_ over 2 years ago in reply to anniel747
  • anniel747
    0 anniel747 over 2 years ago in reply to Ping_
    [deleted]
