Ask an Expert Forum wiring diagram
  • State
  • Subscribers 336 subscribers
  • Views 770 views
See a helpful answer?
wiring diagram
Viren0707
Viren0707 over 1 year ago
We have two tank for Hot and cold water , filling is done manually by the motor starter Start Button, and when tanks are full we have to press stop button. I wish to use 2 relays ( 110V), Float switches , and warning lights when tanks are full. we want when tanks are full  motor should stop itself  triggered by float switch and warning lights should turn on.
Please help in this wiring.
  • bidrohini
    0 bidrohini over 1 year ago
    To automate the motor stop and warning light activation based on the water level in the tanks using float switches, relays, and warning lights, you need a Motor Starter (110V),2 Relays (110V coil voltage),2 Float Switches (one for each tank),2 Warning Lights and one Power Supply (110V AC).
  • kmikemoo
    0 kmikemoo over 1 year ago
    Viren0707 Do you plan to do this with a CodeBug or is this just a general question?
  • Viren0707
    0 Viren0707 over 1 year ago in reply to kmikemoo
    The general question sir , Please help in wiring diagram on this
