Ask an Expert Forum Power supply pin out
  • Replies 8 replies
  • Subscribers 335 subscribers
  • Views 1357 views
See a helpful answer?
inavitech
inavitech over 1 year ago
My company was discarding an old desk top and I removed the power supply from the tower, as I saw it could be useful for other projects and testing. Does anyone work on computers that can provide pin outs for P1 and P2? I know one of the functions is ON/OFF, since plugging it into the wall as is, I just get the green light momentarily and then it goes out.imageimageimageimageimage
  • phoenixcomm
    phoenixcomm over 1 year ago in reply to acdc90 +3
    acdc90 Nope! Nohow! Noway! You can not use a switcher of any type for Audio it should be Linear!!! you will have to throw the kuchen sink full of filters, caps and chokes!!!
  • anniel747
    anniel747 over 1 year ago in reply to inavitech +2
    Deleted
  • inavitech
    inavitech over 1 year ago in reply to anniel747 +2
    Ok, Green wire to black turns power supply outputs ON.
  • anniel747
    0 anniel747 over 1 year ago
    [deleted]
  • inavitech
    0 inavitech over 1 year ago in reply to anniel747
    So I would need to jumper gray to green to turn the outputs ON?
  • anniel747
    0 anniel747 over 1 year ago in reply to inavitech
    [deleted]
  • inavitech
  • acdc90
    0 acdc90 over 1 year ago
    Hello what i found when setting a similar one up as a bench supply
    was i needed to add caps to each rail.
    if running a audio amp it could have noises come through
    this mite say 12A ov 12v but it wont start up with that load already connected.
    and more than likely only uses the 5v rail for its internal regulation.
  • phoenixcomm
    0 phoenixcomm over 1 year ago in reply to acdc90
  • anniel747
    0 anniel747 over 1 year ago in reply to phoenixcomm
    [deleted]
    0 Jan Cumps over 1 year ago in reply to anniel747
    Yes, there are great designs where the PSU is switching, and/or the power stage is class D
    switchers can be (and are) designed so that noise artifacts are outside the audio and sampling ranges.
