Ask an Expert Forum Tenma 72-13200 electronic load: can we turn on and off the remote compensation function programmatically?
  • Subscribers 335 subscribers
  • Views 1000 views
See a helpful answer?
JeremieWerner
JeremieWerner over 1 year ago
the remote compensation function can be turned on by click the buttons: SHIFT+CW
but how to do that programmatically? is there a function for that?
  • Gough Lui
    Gough Lui over 1 year ago +3 suggested
    The load is a Korad KEL103 rebadge. The answer is yes, but it's not actually documented well anywhere to my knowledge. The SCPI command you need is: :SYST:COMP ON If you'd like it off, you can do…
  • aswinvenu
    0 aswinvenu over 1 year ago
    You will have to use the serial port for programming the load. SCPI Is supported. You can find the details in the documents attached.
    72-13300 Series Multiple Channel Remote Control Syntax V2.0
    Aswin
  • Gough Lui
    0 Gough Lui over 1 year ago
    :SYST:COMP ON
    If you'd like it off, you can do :SYST:COMP OFF. It also supports querying :SYST:COMP?
    - Gough
