Ask an Expert Forum Stray readings on my XDM 1041 Multi Meter
  • Replies 14 replies
  • Subscribers 336 subscribers
  • Views 1541 views
See a helpful answer?
FreeBird
FreeBird over 1 year ago
I just want to confirm my suspicions.
I recently read an article by Forrest Mims regarding using LED's as light detectors.  I decided to see how my cheap chinese LED's would react so I plugged 2 wires into 2 adjacent rows on one of my bread boards.  Connected my DMM to them.  I then selected 1 of each color LED from my kit which contains 5 different colors (Red, Blue, Yellow, White and Green).  I noticed however, that I was getting stray voltage readings with nothing connected in the bread board.  I decided to record a series of 500 readings to see what the min, max and average of them would be.  This is what I got:
Min -0.0003
Max 0.0001
Average
-0.000025
I suspect, but would like someone smarter than me to confirm, that this is stray EMF in my lab.  I have a window AC unit running, my computer, a florescent light, etc.  Am I correct in my suspicion?  How might I confirm this, other than asking that is?
Charlie
    shabaz over 1 year ago in reply to shabaz +4
    Curiosity got the better of me, I decided to get off my backside and retrieve the multimeter. Rubbing a piece of plastic onto t-shirt (I used a ruler) and placing the multimeter negative lead near it,…
  • beacon_dave
    beacon_dave over 1 year ago +3
    May also be of interest: Experimenting With Using an LED as a Light Sensor More on Using an LED as a Light Sensor
    shabaz over 1 year ago +2
    Hi, An ideal voltmeter will have infinite impedance, so technically even static charges will cause a non-zero measurement, there's no need for it to be electromagnetic interference. In fact, multimeters…
  • FreeBird
    FreeBird over 1 year ago in reply to md_steve
    I remember reading about someone taking advanatage of the lack of airlines flying to collect data, didn't remember it was him though.  Will have to look up his articles on it.
  • FreeBird
    FreeBird over 1 year ago in reply to robogary
    Nice graphical explanation, thanks.
  • dang74
    dang74 over 1 year ago in reply to FreeBird
    So the fluctuations you see are small relative to those values.
  • opalko
    opalko over 1 year ago in reply to md_steve
    I think you're conflating two different but related things. He did sue Bell Labs, which was part of AT&T, but the work done on the contrails right after 9/11 was David Travis. Travis & Mims did work together earlier however.  Forrest is a really interesting guy with all the things he's worked on.
    https://www.gunn-lee.com/representative-cases (
    When Ted Lee Took on the World's Largest Corporation)
    https://www.nature.com/articles/418601a (Contrails reduce daily temperature range, 2002)
    https://www.researchgate.net/publication/248818024_Aircraft_contrails_reduce_solar_irradiance  (Aircraft contrails reduce solar irradiance, 1997)
