Ask an Expert Forum Nintendo 64 PAL – No Signal After Reassembly
  • Replies 65 replies
  • Subscribers 335 subscribers
  • Views 5643 views
  • console repair
  • help
  • repair
See a helpful answer?
kiltro
kiltro 11 months ago
Hello everyone!
I have a PAL Nintendo 64 with the following issue.
When I first received the console, I disassembled and cleaned it. It worked fine.
Video quality was not great, so I replaced all electrolytic capacitors. The console still worked and I could play games.
After final reassembly in it's case, it started showing “No Signal.”
What I did so far:
Disassembled again, this time also removing heatsinks.
Cleaned everything again: card slot, AV cable, jumper pack contacts (even with 800-grit sandpaper).
Reflowed electrolytic capacitors and main chips: CPU, RCP, PIF, DENC, and jumper pack connector pins.
Tested various points with oscilloscope (I can share waveforms if needed).
Swapped my Expansion Pak with a new Jumper Pak.
Replaced power supply.
AV cable is brand new, so I don't think this is the cause.
Tried inserting/removing cartridge and jumper pack while powered on (as suggested in some threads).
At this point the console still gives no video output at all.
I was hoping that someone can give me some advice or is available to make a comparison between the measurements made on a working console and mine
Here are measurements (in the Gsheet file) and other related stuff
drive.google.com/.../1_iCxMZg6JVUPDNlzgr-V5CmYrW0aUk71
Schematic of one of the NTSC versions. From what I see what differs from mine is from the video encoder to the output connector.
  • dang74
    dang74 11 months ago in reply to kiltro +1 verified
    I have an NTSC version of the N64. I will pull it out of storage and see what's involved in taking it apart. Of course there could be a discrepancy between our waveforms just by virtue of one being PAL…
  • dang74
    It occurred to me that I need a special screw driver to take the case apart. I've ordered the 4.5mm game bit screw driver last night. In terms of basic functionality I observed the following: There was…
  • dang74
    dang74 10 months ago in reply to kiltro +1
    Okay, a more substantial update for you. I took the N64 apart today. The encoder I have is the AVDC-NUS. I did some probing with no cartridge and no jumper pack installed. I will add a disclaimer here…
  • dang74
    0 dang74 10 months ago in reply to kiltro
    Okay, a more substantial update for you.  I took the N64 apart today.  The encoder I have is the AVDC-NUS.  I did some probing with no cartridge and no jumper pack installed.  I will add a disclaimer here.  I have an old 50MHz analog scope so these pulse trains are at the limit of scope"s capability.  In fact instead of square waves I was seeing triangular peaks.  Anyway, the pins that correspond to D0 through D3 had the same type of signal... and in my judgment their duty cycle was less than 50%.  The pins that correspond to D4 through D7 were 0V flat line.  The pin that corresponds to the SYNC signal had an AC waveform.  It's duty cycle was greater than that overserved on D0 through D3.  The pin that is supposed to be the clock had a sine wave.  I suppose it's really a square wave but due to the limitations of my scope I observed it as a sine wave.  My observations are more or less consistent with yours... it's very possible that all your electronics are fine but a poor contact with the jumper pack or cartridge is messing things up.
  • kiltro
    0 kiltro 10 months ago in reply to dang74
    You can see what I have measured so far here
    https://docs.google.com/spreadsheets/d/1GrGj95BcU5GfZvYtvYVBCxaKokOzlmxlZgRDTHP93-8
    DENC sheet in this case
    I see a sinewave on CLK too, it's a 50Hz wave (my digital oscope is 100Mhz)
    I've checked, cleaned again and again, also reflowed the two connectors (card and jumper pack), but I can check again.
    Maybe by opening a card and the jumper pack I can check resistance directly from the two boards and the destination of every signal?
  • dang74
    I like your idea for checking the resistance to the jumper pak to ensure continuity.  You could use the same approach with a cartridge as well. That is of course if you don't mind opening a cartridge up.  Before you do this, I was wondering if you tried using the original jumper pak.  I seem to recall at some point that you switched to a new one.
  • kiltro
    The console was sent to me with an original expansion pack (the one that has red plastic). It was working with that one. Then when the console stopped working, I've bought a jumper pack (not original, completely black) but that doesn't changed anything.
  • acdc90
    0 acdc90 10 months ago in reply to kiltro
    in the spreadsheet you list d0 - d7 is there data moving on those pins. what ics does this use
  • kiltro
    0 kiltro 10 months ago in reply to acdc90
    Hi, yeah if you click on the pin name in the DENC sheet you should see an image of what I'm measuring there (activity on D0-D3, 0V on D4-D6).
    I'm measuring with game and jumper pack inserted
  • kiltro
     dang74 Unfortunately I dont see anything strange on the connectors.
    I've measured from solder pads of the card connector (removing the top connector) and the various arrival pads on the chips, every trace is 0,4-0,6ohm (connecting my probes directly I get 0,2ohm)
    For the jumper pack connector if measure from the spring pin inside to the solder joint (pins-pcb) of the same connector and I get 0,4 ohms
  • dang74
    I thought of an alternate way of testing that the jumper pak is making good contact.  I came across a site that shows which pins connect to the resistors and which pins connect to VTT.  (See link below.)
    Anyway general strategy is to:
    1) Install the jumper pak
    2) Position one multimeter probe at the pin 8 SMT pad on the N64 board (pin 8 directly connects to VTT)
    3)  Position the other multimeter probe on the pin 5 SMT pad on the N64 board (pin 5 is one of the pins that connect to a resistor)
    4) If you measure low impedance like 100 OHMs then you know you have good contact between 5 and 8.  On the other hand if its open load or high impedance then you have poor contact.
    5) Repeat general process for other pins that connect to a resistor (7,9,11 etc)
    There is one complication to this.  If the jumper pak is in its case it completely obscures the SMT pads that need to be probed... and I am not sure how easy the task will be even if the jumper pak is removed from the PCB.
    bitbuilt.net/.../
  • kiltro
     dang74 Actually it's quite easy once the jumper pack is remove from it's case
    I measure 51ohm for every resistor, using pin8 as common.
    The only one that I strangely measure as 40ohms is the one connected to pin15.
    I've also measured resistance from all ground pins to ground and they seem fine
    Caps on the board to gnd it's ok too
  • dang74
    0 dang74 10 months ago in reply to dang74
    I think the RAMBus connection on the N64 is passively daisy chained through the ICs.... so even without power you can measure continuity through the devices.  Long story short, the 12 RamBus signals at the Jumper Pak which are hard to probe can be probed elsewhere on the board.  Yesterday I measured the impedance from vias situated near the PIF to VTT and I was getting about 200 OHMs with the Jump Pak installed.  I think the impedance was open load without the Jumper Pak installed... but I have to double check this.  By the way on the bottom side of my N64 there is a VTT test point.
