Ask an Expert Forum Nintendo 64 PAL – No Signal After Reassembly
  • Replies 65 replies
  • Subscribers 335 subscribers
  • Views 5640 views
  • console repair
  • help
  • repair
See a helpful answer?
kiltro
kiltro 11 months ago
Hello everyone!
I have a PAL Nintendo 64 with the following issue.
When I first received the console, I disassembled and cleaned it. It worked fine.
Video quality was not great, so I replaced all electrolytic capacitors. The console still worked and I could play games.
After final reassembly in it's case, it started showing “No Signal.”
What I did so far:
Disassembled again, this time also removing heatsinks.
Cleaned everything again: card slot, AV cable, jumper pack contacts (even with 800-grit sandpaper).
Reflowed electrolytic capacitors and main chips: CPU, RCP, PIF, DENC, and jumper pack connector pins.
Tested various points with oscilloscope (I can share waveforms if needed).
Swapped my Expansion Pak with a new Jumper Pak.
Replaced power supply.
AV cable is brand new, so I don't think this is the cause.
Tried inserting/removing cartridge and jumper pack while powered on (as suggested in some threads).
At this point the console still gives no video output at all.
I was hoping that someone can give me some advice or is available to make a comparison between the measurements made on a working console and mine
Here are measurements (in the Gsheet file) and other related stuff
drive.google.com/.../1_iCxMZg6JVUPDNlzgr-V5CmYrW0aUk71
Schematic of one of the NTSC versions. From what I see what differs from mine is from the video encoder to the output connector.
  • dang74
    dang74 11 months ago in reply to kiltro +1 verified
    I have an NTSC version of the N64. I will pull it out of storage and see what's involved in taking it apart. Of course there could be a discrepancy between our waveforms just by virtue of one being PAL…
  • dang74
    It occurred to me that I need a special screw driver to take the case apart. I've ordered the 4.5mm game bit screw driver last night. In terms of basic functionality I observed the following: There was…
  • dang74
    dang74 10 months ago in reply to kiltro +1
    Okay, a more substantial update for you. I took the N64 apart today. The encoder I have is the AVDC-NUS. I did some probing with no cartridge and no jumper pack installed. I will add a disclaimer here…
  • dang74
    0 dang74 10 months ago in reply to kiltro
    I am less inclined to suspect the video cable because the waveforms you observed at the encoder inputs match what I was seeing when I had no cartridge and no jumper pack.
  • kiltro
    0 kiltro 10 months ago in reply to dang74
    Maybe you can check what you have on D0-D6 and screen when:
    - Only card game inserted
    - Only jumper pack
    - Both inserted but no controller
  • kiltro
    Main problem with checking continuity between card pcb and main pcb is that I can't access the pin on the card when it is inserted...
    I would have to trace every pin and see were it goes on the board
    This is one cards that was working btw
  • dang74
    I see what you mean.  I thought there would be obvious visible  traces going to some memory chips.  This looks like a more modern multicart.  The MAXII CPLD for instance didn't come out during the N64 consoles life cycle.  Do you have any old school carts?
  • dang74
    For what it's worth I've taken my top cartridge connector off and cleaned underneath it.  When I powered the N64 up with a cartridge and jumper pack installed I had no video on start up initially.  I fiddled with the cartridge connector and at some point exerted some downward force on the one chip closest to the cartridge connector.  Not sure which of these two actions fixed the problem... but now things are fine.
  • kiltro
    Chip closest to the cartridge you mean the rcp?
  • dang74
    Yes
  • kiltro
    Small update:
    - Tried different cable (the one in the vid)
    - Tried wiggling things around and pressing on chips
    Unfortunately doesn't solve the issue
  • kiltro
    I've also found an older game, Mario 64. The pcb is much simpler so maybe I can try continuity using that.
  • dang74
    From the video I get the impression that your cartridge connector doesn't grip the cartridge as tightly as mine does.  It seems like it is very easy for you to jiggle it... but maybe it just appears that way.
