Ask an Expert Forum Nintendo 64 PAL – No Signal After Reassembly
  • Replies 65 replies
  • Subscribers 335 subscribers
  • Views 5641 views
  • console repair
  • help
  • repair
See a helpful answer?
kiltro
kiltro 11 months ago
Hello everyone!
I have a PAL Nintendo 64 with the following issue.
When I first received the console, I disassembled and cleaned it. It worked fine.
Video quality was not great, so I replaced all electrolytic capacitors. The console still worked and I could play games.
After final reassembly in it's case, it started showing “No Signal.”
What I did so far:
Disassembled again, this time also removing heatsinks.
Cleaned everything again: card slot, AV cable, jumper pack contacts (even with 800-grit sandpaper).
Reflowed electrolytic capacitors and main chips: CPU, RCP, PIF, DENC, and jumper pack connector pins.
Tested various points with oscilloscope (I can share waveforms if needed).
Swapped my Expansion Pak with a new Jumper Pak.
Replaced power supply.
AV cable is brand new, so I don't think this is the cause.
Tried inserting/removing cartridge and jumper pack while powered on (as suggested in some threads).
At this point the console still gives no video output at all.
I was hoping that someone can give me some advice or is available to make a comparison between the measurements made on a working console and mine
Here are measurements (in the Gsheet file) and other related stuff
drive.google.com/.../1_iCxMZg6JVUPDNlzgr-V5CmYrW0aUk71
Schematic of one of the NTSC versions. From what I see what differs from mine is from the video encoder to the output connector.
  • dang74
    dang74 11 months ago in reply to kiltro +1 verified
    I have an NTSC version of the N64. I will pull it out of storage and see what's involved in taking it apart. Of course there could be a discrepancy between our waveforms just by virtue of one being PAL…
  • dang74
    It occurred to me that I need a special screw driver to take the case apart. I've ordered the 4.5mm game bit screw driver last night. In terms of basic functionality I observed the following: There was…
  • dang74
    dang74 10 months ago in reply to kiltro +1
    Okay, a more substantial update for you. I took the N64 apart today. The encoder I have is the AVDC-NUS. I did some probing with no cartridge and no jumper pack installed. I will add a disclaimer here…
  • dang74
    0 dang74 10 months ago in reply to kiltro
    Good.  Hopefully it is easier to see where the traces go.
  • kiltro
    0 kiltro 10 months ago in reply to dang74
    I'm testing resistance directly on the cartridge PCB pads and the terminals on the motherboard. I still have to finish, but for now I'd say it's good, I'm getting 0.4 ohms. On some lines, tilting the game PCB towards me increases the resistance to 15-17 ohms.
    It's a bit tricky to be sure, but testing between the cartridge and the pins of the upper connector (the ones that fit into the lower connector) shows that the resistance doesn't change even when tilting the cartridge, so I assume the problem lies in the interlocking system between these pins and the plugs in the connector under the motherboard.
    That said, it could be completely normal, since it's practically impossible to get the cartridge to be in such an inclined position without forcing it. Also, with the console turned on, even tilting it back and forth still causes the problem.
    Another note... yesterday the screen I'm using for the test suddenly stopped working... lol, the screen's power supply suddenly stopped supplying 19 VDC, now I'm using the benchtop power supply to turn on the screen.
  • kiltro
    dang74  So, I've measured all the connector to mainboard connections and they seem fine to me... something like 0,4-1ohm (there is probes resistance in there too)
    Now I'm not sure where to look...
    I see some people have problems with C73 (it's the 68u near the power swtich). Mine is new, and I have checked it measure 68uf, but what do you measure with resistance mode on his pins?
    I get something like 280ohms
  • dang74
    Looks like it isn't the cartridge connector then.  I will measure the resitance across C73 and/or the capacitor near the power switch tonight.
  • acdc90
    0 acdc90 10 months ago in reply to dang74
    on your working NTSC machine when the cartridge is not installed Do you still have H and V sync on the composite video signal ?
  • dang74
    0 dang74 10 months ago in reply to acdc90
    In that scenario the SYNCH signal at the input of the encoder is produced.  I did not examine what happens at the cable.
  • dang74
    I measured the resistance across C73 and it was 283 OHMs.
  • kiltro
    That's ok too then... Confused
    Maybe I should try a crt tv, if I can find one.
    Do you have activity o D4-D6 whith game and jumper pack inserted?
  • dang74
    Okay, I will check tonight.  If you are getting activity D4-D6 that is a good sign.... and maybe an older CRT that doesn't go blue at the smallest issue can give some clues.
  • kiltro
    I'm not. That's why I'm asking if you are sure there is on yours
