Ask an Expert Forum Nintendo 64 PAL – No Signal After Reassembly
  • Replies 65 replies
  • Subscribers 335 subscribers
  • Views 5647 views
  • console repair
  • help
  • repair
See a helpful answer?
kiltro
kiltro 11 months ago
Hello everyone!
I have a PAL Nintendo 64 with the following issue.
When I first received the console, I disassembled and cleaned it. It worked fine.
Video quality was not great, so I replaced all electrolytic capacitors. The console still worked and I could play games.
After final reassembly in it's case, it started showing “No Signal.”
What I did so far:
Disassembled again, this time also removing heatsinks.
Cleaned everything again: card slot, AV cable, jumper pack contacts (even with 800-grit sandpaper).
Reflowed electrolytic capacitors and main chips: CPU, RCP, PIF, DENC, and jumper pack connector pins.
Tested various points with oscilloscope (I can share waveforms if needed).
Swapped my Expansion Pak with a new Jumper Pak.
Replaced power supply.
AV cable is brand new, so I don't think this is the cause.
Tried inserting/removing cartridge and jumper pack while powered on (as suggested in some threads).
At this point the console still gives no video output at all.
I was hoping that someone can give me some advice or is available to make a comparison between the measurements made on a working console and mine
Here are measurements (in the Gsheet file) and other related stuff
drive.google.com/.../1_iCxMZg6JVUPDNlzgr-V5CmYrW0aUk71
Schematic of one of the NTSC versions. From what I see what differs from mine is from the video encoder to the output connector.
  • dang74
    dang74 11 months ago in reply to kiltro +1 verified
    I have an NTSC version of the N64. I will pull it out of storage and see what's involved in taking it apart. Of course there could be a discrepancy between our waveforms just by virtue of one being PAL…
  • dang74
    It occurred to me that I need a special screw driver to take the case apart. I've ordered the 4.5mm game bit screw driver last night. In terms of basic functionality I observed the following: There was…
  • dang74
    dang74 10 months ago in reply to kiltro +1
    Okay, a more substantial update for you. I took the N64 apart today. The encoder I have is the AVDC-NUS. I did some probing with no cartridge and no jumper pack installed. I will add a disclaimer here…
  • kiltro
    0 kiltro 10 months ago in reply to dang74
     dang74 acdc90  Indeed I dont have anything like that. Also about the possible bridge on CPU pins, it's not there.
    I'm still waiting for a thermal cam to see if I see something unusual.
    But currently I'm not sure how to proceed.
    Maybe making measurments on the rams? But that I thing would need a lot more than my 100Mhz scope
  • dang74
    0 dang74 10 months ago in reply to kiltro
    Yeah, it's tough.   I knew it would be challenging but I underestimated the difficulty level.
  • kiltro
    0 kiltro 9 months ago in reply to dang74
    Little update, I've received a new thermal cam.
    I'm still learning how to use it but in this video what I see is that one of the two ram seem completely dead?
  • dang74
    0 dang74 9 months ago in reply to kiltro
    Ah, so the RAM chip closest to the jumper pack is lifeless (not generating heat.)  Have you checked on the availability of that chip?
  • kiltro
    Not yet, but I dont think it is Confused
