Ask an Expert Forum What kind of adhesive or glue should I use to bind them?
  • Replies 24 replies
  • Answers 2 answers
  • Subscribers 335 subscribers
  • Views 2836 views
  • adhesive
  • glue
See a helpful answer?
HKPhysicist
HKPhysicist 10 months ago
Hello Experts,
I am looking for a kind of adhesive or glue which can bind a tiny Li+ion battery to a hard plastic ABS enclosure's bottom.
Could you suggest a good adhesive or glue for my goal?  Here are my Li+ion battery and my hard plastic (ABS) enclosure.
Thanks for your attention and opinions.Relaxed
  • Gough Lui
    Gough Lui 10 months ago +3 suggested
    Ideally you wouldn't use glue, but double sided foam adhesive tape or similar. This reduces the chance of damaging the pouch, especially as the cell can swell throughout its life and needs some ability…
  • strb
    strb 10 months ago +1
    +1 on hot glue (you can easily remove the glue simply by dripping some alcohol on in and peeling it off in case you need to remove the battery) or double sided tape (the foamy one, so it can fill the gap…
  • HKPhysicist
    HKPhysicist 10 months ago in reply to strb +1
    Double sided foam tape sounds good. It is cheap, non-corrosive, easy to apply.
  • Sabriella03
    0 Sabriella03 10 months ago in reply to kmikemoo
    For most electronics, I'm a big fan of 'Neutral Cure' RTV silicone. It doesn't have that vinegary smell (which can actually corrode your components) and it provides a great vibration-resistant bond. Plus, you can usually peel it off later with a bit of patience if you need to make repairs!
  • HKPhysicist
    0 HKPhysicist 10 months ago in reply to Sabriella03
    Is "Neutral Cure RTV silicone" the same as the usual silicone adhesive used in sealing aluminium window frame?
  • Biasio
    0 Biasio 10 months ago
    [deleted]
    0 Jan Cumps 10 months ago in reply to Biasio
    AI generated
