Ask an Expert Forum What sensor can I use to determine rotation?
  • Replies 12 replies
  • Answers 2 answers
  • Subscribers 335 subscribers
  • Views 1297 views
  • members
  • help
  • engineering
See a helpful answer?
Aniket_kumar_raj
Aniket_kumar_raj 9 months ago
Guys is there any sensor online that is small to fit between two finger joints and calculate how much degrees its turned, i am lanning to make a glove that has ability to see at what position fingers are turned to.
I thaught of potentiometer but its too large to fit between finger joints, also what i men to say is that i am making a glove like thing where a sensor is needed which can be attached at finger joints to see ho much is it turned
    michaelkellett 9 months ago +3
    https://duckduckgo.com/?t=ffab&q=HOW+DO+SENSOR+GLOVES+WORK&atb=v101-1&ia=images&iax=images&iai=https%3A%2F%2Fpub.mdpi-res.com%2Fsensors%2Fsensors-23-06693%2Farticle_deploy%2Fhtml%2Fimages%2Fsensors-23…
  • SensoredHacker0
    SensoredHacker0 9 months ago +3 verified
    accelorometer, inclinometer, gyroscopes can all do this. depending on how you do joint articulation you may be able to use a magnomometer, or encoder. then you can also make your own sensors with that…
  • beacon_dave
    beacon_dave 9 months ago +3 suggested
    I recall that there are some sensor glove based student projects listed here: https://people.ece.cornell.edu/land/courses/ece4760/FinalProjects/
    0 shabaz 9 months ago in reply to beacon_dave
    Bourns also has quite small linear sensors intended for robotics (LMP series), I have a load of those (surplus) waiting for a good rainy day project!
    For hand and finger position sensing Leap Motion Controller 2 is probably quite good too - I've used the much older version 1 product, really very neat. These products can be attached to head or chest, facing toward hands. They rely on a PC for processing the data, but PCs can be quite small these days.
  • beacon_dave
    0 beacon_dave 9 months ago in reply to shabaz
    They look pretty neat. Roll on the rainy day project Slight smile
    If anchored to points on the finger either side of the knuckle, forming the third side of a triangle, it should be able to calculate the angle of rotation at the knuckle.
