Ask an Expert Forum What sensor can I use to determine rotation?
  • Replies 12 replies
  • Answers 2 answers
  • Subscribers 335 subscribers
  • Views 1296 views
  • members
  • help
  • engineering
See a helpful answer?
Aniket_kumar_raj
Aniket_kumar_raj 9 months ago
Guys is there any sensor online that is small to fit between two finger joints and calculate how much degrees its turned, i am lanning to make a glove that has ability to see at what position fingers are turned to.
I thaught of potentiometer but its too large to fit between finger joints, also what i men to say is that i am making a glove like thing where a sensor is needed which can be attached at finger joints to see ho much is it turned
    michaelkellett 9 months ago +3
    https://duckduckgo.com/?t=ffab&q=HOW+DO+SENSOR+GLOVES+WORK&atb=v101-1&ia=images&iax=images&iai=https%3A%2F%2Fpub.mdpi-res.com%2Fsensors%2Fsensors-23-06693%2Farticle_deploy%2Fhtml%2Fimages%2Fsensors-23…
  • SensoredHacker0
    SensoredHacker0 9 months ago +3 verified
    accelorometer, inclinometer, gyroscopes can all do this. depending on how you do joint articulation you may be able to use a magnomometer, or encoder. then you can also make your own sensors with that…
  • beacon_dave
    beacon_dave 9 months ago +3 suggested
    I recall that there are some sensor glove based student projects listed here: https://people.ece.cornell.edu/land/courses/ece4760/FinalProjects/
    0 michaelkellett 9 months ago
    https://duckduckgo.com/?t=ffab&q=HOW+DO+SENSOR+GLOVES+WORK&atb=v101-1&ia=images&iax=images&iai=https%3A%2F%2Fpub.mdpi-res.com%2Fsensors%2Fsensors-23-06693%2Farticle_deploy%2Fhtml%2Fimages%2Fsensors-23-06693-g003.png%3F1690373659
    There is  a lot of information about this on the web.
  • SensoredHacker0
    +1 SensoredHacker0 9 months ago
    then you can also make your own sensors with that packing foam, and conductive thread.
    you could read the capacitance changes, or...
    well there is a lot of things you could do, without further detail on constriction, it s hard to say.
    is it joint position in 3d space?
    ** WUT WUT?!? **
    >> Gang signs detected!
  • Aniket_kumar_raj
    0 Aniket_kumar_raj 9 months ago in reply to SensoredHacker0
    good idea but why not flex sensor ,its more good if i want it to directly touch to skin ,it wont even give a scratch or cut on skin
  • robogary
    +1 robogary 9 months ago in reply to Aniket_kumar_raj
    There are always multiple ways to approach a solution. Give flex sensor a test and let us know result. Which flex sensor are you considering ?
    I was thinking a micro absolute encoder , but there would need to be an rigid exo-skeketon. The sensor accuracy wearing gloves or other attachment would have inherent slippage.
    Solid state sensors like magnetometers, imu, gyros involve alot of calibration,  calculation,  and proper filtering, which why I only use them when they are the best solution.
  • Aniket_kumar_raj
    0 Aniket_kumar_raj 9 months ago in reply to robogary
    ok, i will use the sensor as u suggest so which is most perfect sensor in this case
  • beacon_dave
    0 beacon_dave 9 months ago
    +1 dougw 9 months ago
    I have one of these Essential Reality P5 gloves. This video from LGR provides some insight into what kind of performance you might achieve....
    https://www.youtube.com/watch?v=wOSmrpw89SI
    0 dougw 9 months ago
    Another commercial example...
    QD023 Motion-Sensing Glove for Robot Control – ACEBOTT
  • beacon_dave
    +1 beacon_dave 9 months ago
    Perhaps take a look at some of the small SMD ones ?
    Bourns do some thin rotary position sensors:
    https://www.bourns.com/data/global/pdfs/3382.pdf
  • SensoredHacker0
    0 SensoredHacker0 9 months ago in reply to robogary
    flex sensors are a thing, they are prone to mechanical failure.
    you can make them, for pennies, which is what I was trying to suggest.
    IDK, I cant find the videos of mine right now.
    well, if you're going to choose the method prone to mechanical breakage, dont go with 5$ sensors.
