Ask an Expert Forum Raspberry PI 5 OS version?
  • Replies 17 replies
  • Subscribers 336 subscribers
  • Views 3553 views
See a helpful answer?
Rory_D
Rory_D 9 months ago
What is the version of raspberry pi OS that is shipped with the Raspberry Pi 5 starter kit RPI5-STARTERKIT-8GB-US?
  • BigG
    BigG 9 months ago +3
    It's probably worth asking your question on the official raspberry pi forum https://forums.raspberrypi.com/ rather than here, then it's quite likely that an actual Raspberry Pi engineer will give you the…
  • beacon_dave
    beacon_dave 9 months ago +3
    There has been at least one Product Change Notice issued on that starter kit, which states that the bundled microSD card has been changed.
  • misaz
    misaz 9 months ago +2
    I am not an expert, but I guess that it even depends when you bought it. You can update to latest by running following command in terminal sudo apt update sudo apt full-upgrade
  • misaz
    0 misaz 9 months ago
    sudo apt update
    0 shabaz 9 months ago
    Alternatively, you could also just get a new blank microSD card, and freshly install the latest, see https://www.raspberrypi.com/documentation/computers/os.html
    I'm not sure it really matters what version was delivered in the kit, since it's fairly likely to be older than what's available today. Also, usually kits come with a minimal-sized microSD card, which may eventually be limiting.
  • Rory_D
    0 Rory_D 9 months ago
    Thanks, but I'm not asking for recommendations or opinions about which OS I *should* run.
    I'm asking a factual question:
    **What OS version was actually flashed onto the microSD card included in this specific Multicomp Pro Raspberry Pi 5 starter kit sold by Element 14?**
    I'm looking for a stable, PI-optimized baseline - not the "latest".
    If you have the kit, please share the version your card was shipped with. If you don't have the kit, that's okay but you're not actually answering my question.
    • Vote Up -2 Vote Down
    0 shabaz 9 months ago in reply to Rory_D
    Regarding:
    "I'm looking for a stable, PI-optimized baseline - not the "latest". "
    It's an unrealistic assumption that the supplied release may be more stable. Here's how I know: If you're in any doubt, check the release notes, and you'll see that the current latest release (about six weeks old now) fixes a number of bugs, and was introduced less than two weeks before the prior version, so even without me digging deeper, I can see that if anything, the assumption is that it's indeed an important update compared to the one immediately prior to it.
    Since only you know your use case(s), you'd need to, at a minimum, review the release notes if you're considering running an older release. All releases will have bugs; you can only know if it may be stable for your use case by looking to see what issues have been reported and whether you can work around them.
    For what it's worth, I have a brand new Pi 5, and it will receive that latest release unless I read otherwise, i.e. if any adverse news comes to light concerning that release.
  • Rory_D
    0 Rory_D 9 months ago in reply to shabaz
    Thanks for taking the time to reply. My question is specifically about the stability of the pre‑installed Pi 5 image, so your answer doesn’t really address what I’m trying to find out. I’m looking for input from people who’ve actually used that baseline.
    You have valid points but it's just not what I'm asking for. Again, thanks.
  • colporteur
    0 colporteur 9 months ago in reply to Rory_D
    Let's hope someone in the community can provide an answer, it sounds like it has some importance.
    What you are asking for on the surface appears simple but in actual fact it has a number of nuances that alter the answer.
    I'm going to assume (i.e. haven't worked a Pi production line) that the baseline release for a runs depends on when the run began. The Pi O/S is in steady state of change. The first Pi 5's of the production line would not have the release that is on new Pi 5's. It would have changed.
    Two of the terms come to mind as nuance changing. Stable and baseline. Define stable and define baseline?
    Running a Pi out of the box without performing an apt update/apt upgrade would be fool hardy. The upgrade alters the O/S. What is baseline and what is stable. Is it before or after the upgrade.
    I've pulled an OS the day of its release and have a run apt upgrade. Some stuff changed. Hey wait, I thought the baseline was stable?
    Can you help us understand why the fixation on the O/S out of the box? Is there a kernel you are looking for or a specific release of a software package tied to a release?
  • Rory_D
    0 Rory_D 9 months ago in reply to colporteur
    Thanks for the thoughtful write‑up. I think we may be talking past each other a bit.
    I’m not trying to define “stable” in the abstract or debate whether apt‑upgrade is good practice. I’m trying to identify the specific Raspberry Pi OS image that Multicomp Pro pre‑flashed onto the SD card in this starter kit, because that’s the environment the Pi 5 hardware was validated against at packaging time.
    Different OS releases have shown different behaviors on Pi 5 hardware (kernel, firmware, Wayland/X11 defaults, etc.), so knowing the exact shipped version helps me establish a deterministic baseline before making changes.
    If anyone has this same kit and can check the pre‑installed image version—or has insight into which release Multicomp Pro was flashing during that production window—that’s the piece of information I’m trying to pin down.
    0 michaelkellett 9 months ago in reply to Rory_D
    I think you are perhaps expecting a bit more from the Pi than it is intended or priced to deliver.
    If you want a known software release pinned down to the last byte and actually validated against the hardware at the time of shipping then you are not in low cost, off the shelf Linux territory. There are people who can offer this service but it will cost you a lot of money.
    Your only hope with the Pi is to ask the people you bought it from.
  • BigG
    0 BigG 9 months ago
    It's probably worth asking your question on the official raspberry pi forum https://forums.raspberrypi.com/ rather than here, then it's quite likely that an actual Raspberry Pi engineer will give you the answer you're looking for. We're all end-users.
  • Rory_D
    Element14’s own subsidiary produced this kit, sourced the components, and packaged it. The box directs users to “Full Instructions at: element14.com/raspberrypi,” so it’s reasonable to expect that the OS image version would be documented somewhere. I couldn't find it anywhere on the website.
    Even a small slip of paper placed in the box at the same time the microSD card was packed would have solved this. Instead, the only support path is a peer-to-peer forum where end-users can only guess at details Element14 already knows.
    reasonable to expect that the baseline OS image would be documented somewhere.
    where end-users can only guess at details Element14 already knows.Element14’s own subsidiary produced this kit, sourced the components, and packaged it. The box directs users to “Full Instructions at: element14.com/raspberrypi,” so it’s reasonable to expect that the baseline OS image would be documented somewhere. Even a small slip of paper placed in the box at the same time the microSD card was packed would have solved this. Instead, the only support path is a peer-to-peer forum where end-users can only guess at details Element14 already knows.
