Ask an Expert Forum Green laser diode
  • Replies 17 replies
  • Subscribers 335 subscribers
  • Views 1615 views
See a helpful answer?
Green laser diode
Hayden40
Hayden40 9 months ago
  1. Anyone kno which green laser diode will project a 90 degree pattern parallel to the floor to reveal dust
    michaelkellett 9 months ago +3
    Dyson explain how it works here: https://www.dyson.co.uk/discover/archive/2021/inside-the-tech-v15-detect I expect they have patents which you could find and there is no problem copying for personal…
  • rsc
    rsc 9 months ago +2
    Like this: This is the lens I attach to the Laser module You can also get a laser line level at a hardware store. They use them to put up celling tiles. Some pet stores have small handheld laser…
  • robogary
    robogary 9 months ago +1
    any laser diode will do that if you mount lt on a servo to rotate it 90 degrees, parallel close to the floor. Lasers have a narrow beamwidth so they need rotated or using some lens for dispersal or rotation…
  • Hayden40
    0 Hayden40 9 months ago in reply to olivia_49
    Fyi i have a 532nm mini green laser that projects a line, problem is, the line is to thin when shining parallel to the floor. I need a lens to basically make the laser line fatter to be able to show dust at least 300mm in front of me. Make sense?
  • beacon_dave
    0 beacon_dave 9 months ago in reply to Hayden40
    May be of interest:
    Forming a Light Sheet
  • colporteur
    0 colporteur 9 months ago in reply to olivia_49
    I would emphasize CAUTION when working with laser light sources. The eye damage they have the potential to create is permanent. I recommend you fix them to a solid structure and not dangle at the end of a cable during development. Paranoia regarding other humans and animals should be your reality.
  • Hayden40
    0 Hayden40 9 months ago in reply to beacon_dave
    Thank you
  • Hayden40
    0 Hayden40 9 months ago in reply to colporteur
    I have a class 1 and safety is top priority, I've got 6 kids lol
  • colporteur
    0 colporteur 9 months ago in reply to Hayden40
    Bright and shiny objects attract kids and of course they have to pick it up and stare at it.
  • rsc
    0 rsc 9 months ago
    Like this:
    You can also get a laser line level at a hardware store.  They use them to put up celling tiles.  Some pet stores have small handheld laser pointers with different line generating caps as cat/dog toys for a few dollars - usually the batteries cost more than the laser.
