Ask an Expert Forum I would like to know as a DIY hobbist which programming language should I opt for programing DIY Development board
  • Subscribers 336 subscribers
  • Views 553 views
  • ask_a_question
See a helpful answer?
manojroy123
manojroy123 7 months ago
I would like to know as a DIY hobbist which programming language should I opt for programing DIY Development board. I am intrested in building test instruments that requires use of GUI and voltage measurement and also use of Raspberri pi SBC for some projects and I would like to makes thoes project open source.
  • Andrew J
    Andrew J 7 months ago +1 verified
    C and possibly Python. Probably depends upon the board and toolsets which will dictate what you use.
  • vmate
    vmate 7 months ago +1 verified
    C# with XAML is also a good contender, as the GUI framework is top notch. It's mainly for Windows, but there are options for cross platform GUIs, like Avalonia. It's a bit more difficult than Python…
  • rsjawale24
    rsjawale24 7 months ago +1 verified
    python. I'm using python with pyserial library to read from instruments and display live data on GUI using pyQT. But in the industry, C# is widely used for instrument interfacing along with GUI
  • Andrew J
    +1 Andrew J 7 months ago
  • vmate
    +1 vmate 7 months ago
    It's a bit more difficult than Python, but still nowhere near as difficult and time consuming as C/C++.
    For MCUs, C is basically your only option, I wouldn't bother with Python, and C++ is just extra complexity that you do not yet need.
    On Windows/Linux, Python is almost certainly the easiest, but the GUI options are pretty horrible.
  • rsjawale24
    +1 rsjawale24 7 months ago
    python.
