Ask an Expert Forum How to measure an impedance of an nfc antenna
  • Replies 14 replies
  • Answers 2 answers
  • Subscribers 337 subscribers
  • Views 1300 views
See a helpful answer?
Luka851
Luka851 5 months ago
I want to make a custom dimension - 20mm x 320 mm - external antenna coil for PN5180 NFC Module/Chip.
To do this I need to design an antenna that has inductance of 0.8-3 microhenry, and then a matching circuit to match with the chip/s 20 ohm load impedance at 13.56 MHz.
I only have an oscilloscope and a signal generator.
My questions are,
1. How do I measure inductance of the following antennas
2. How do I measure impedance on the pn5180 module, and when I do, the result should be 20 ohm, right?
3. Can I measure inductance of the antenna on the pcb? I should disconnect the matching circucit to do it, right?
4. How do I disconnect the pcb antenna from the module and connect to it either of two coils from photos above.
    shabaz 5 months ago +7
    Fairly sure Fred27 did some interesting work in this area a few years back, so you could google for that and find his blogs. Also, there are quite a few ways to measure inductance with minimal test equipment…
  • BigG
    BigG 5 months ago +4
    Get hold of one of these VNA's for impedance measurements: Low-cost Vector Network Analyzer: NanoVNA-H4 Unboxing If you searched online you'd find. And no I haven't watched: https://www.youtube.com/watch…
  • Fred27
    Fred27 5 months ago +4 suggested
    As Shabaz and BigG have said, a VNA is ideal for not just measuring your antenna, but calculating and checking the component values for the matching circuit. NXP provide good documentation on this, but…
  • BigG
    0 BigG 5 months ago in reply to Luka851
    I feel like a London bus. You've waited for ages to hear back and then you get 2 replies almost one after the other.
    I purchased my nanoVNA back in 2019 from banggood. The H4 is a step up and has replaced my version. I believe one of the key decision criteria is what max frequency do you want to measure. If it's NFC (13.56MHz) then the nanoVNA is up to the job. If you're looking at much higher frequencies (near the GHz range) then the nanoVNA is probably not good enough. If you're in the EU, then this website (eleshop.eu) is worth buying from as they source orginal equipment and the pricing is pretty good. I see they sell another device "LiteVNA 64 vector network analyser" which is a step up from the nanoVNA and still very reasonably priced.
    EDIT: As usual, I post then think of other things to add. Here is a review of another "nanoVNA" which is similar to the LiteVNA, in terms of top end scan frequency. The product "NanoVNA-F V3" was from banggood too. At the end of the video "IMSAI Guy" mentions he has a play list covering nanoVNA. Probably worth a watch.
    0 shabaz 5 months ago in reply to shabaz
    Forgot to mention the price.. when I purchased, it was 59.68GBP (including taxes and shipping) for the H4 with "test kit" (a few cables and simple open/short/load pieces). I also purchased a couple of "SS405" cables at the same time, that cost an extra £12 GBP.
  • Luka851
    0 Luka851 5 months ago in reply to BigG
    Thanks again BigG, I am around Europe but not EU. Ookey, this is good! I appretiate it! It took me time, because I was reading articles from the other guy, to reply with more educated answer..
  • Luka851
    0 Luka851 5 months ago in reply to shabaz
    Thanks once again. I intend to become rf--> nfc engineer, through I am a social, political scientist by education. Finished reading RFID handbook by Klaus Finkenzeller some time ago. Thank you once again and I will try to achieve the good results.
