Hi guys,
i have a problem with the right trigger of my X1 controller.
it is acting like it is permanently pressed.
I did some research but havent found anything helpful so far.
I opened the controller to check if the magnet was lose or not in the right position anymore, but it is where it has to be.
Then i checked the voltages of the hall effect sensors. Both are at about 250mV when the trigger is not pressed.
When i press the trigger, the voltage decreases accordingly, all as it should be.
But still, the right trigger permafires..
Any help would be great!
Sorry for my lousy english :/
Greets from Germany
Ted
