Ask an Expert Forum TDC-06 -  TERMINAL BLOCK, BARRIER, 6 POSITION, 18-12AWG
  • Subscribers 337 subscribers
  • Views 574 views
  • terminal_blocks
See a helpful answer?
p75213
p75213 over 8 years ago
I can't find the screw size in the technical datasheet. Can somebody help with that?
  • phoenixcomm
    phoenixcomm over 8 years ago
    It all depends on spec that the terminal strip was built to. The problem is multicomp, It is a Newark-E14-Farnell aberration, it's not a manufacturer, it's just a jobber owned by Farnell. Personally, You get what you pay for. Me I like Chinch, Molex, Amp (now Tyco most of the time you can find the size of the screw. I found this for you never know. https://www.alliedelec.com/cinch-8-140-y/70152873/?mkwid=sK7MIcUcd&pcrid=88929333499&gclid=CjwKCAjwgvfOBRB7EiwAeP7ehpybn…
    on the spec sheet, it calls out for
    Screw Size:5-40 x 3⁄16
    Chinch 6-32x1/4 that mostly standard for that size:https://belfuse.com/resources/Barriers/141Connector/cinch-barrier141.pdf
    but I don't know If your screws go all the through or not
    BTW I took me about 1hr with Mr. Google
    Im missing my shows and gota eat..
    Later
