Ask an Expert Forum Oscilloscope - Total noob
  • Replies 15 replies
  • Subscribers 307 subscribers
  • Views 4238 views
See a helpful answer?
Andy Betts
Andy Betts over 7 years ago
Taking my first steps into electronics, I've been playing around making guitar effects pedals and posting on my blog the outcomes from those adventures, it's been fun but there is one thing that keeps slapping me in the face..... The lack of advice for newby electronics hobbyists.
I fell into electronics as a way of making pedals for myself as I couldn't afford to buy the real thing. However, it's been made quite apparent in previous blog posts that if you're going to have fun with electronics you need the right kit. I seem to have most bases covered except the illusive Oscilloscope. To the uninitiated (me) they look technical, and the sort of thing you see in a NASA control room. However, using one is only one part of the issue...... How do you go around buying one, and what do you buy. Is it safe to buy second hand from that famous auction site, or should you buy brand new? Is there any advantage of digital over analogue? The older analogue scopes look cool and retro but are there limitations? What should the minimum specification be that I'm looking for?
This forum is great for electronics enthusiasts, and the amount of knowledge here is huge, but it appears the assumption could be it's for people that already know these things. that's why i'm putting this out there as a newby question. I want to buy an Oscilloscope, i'm on a budget, say a maximum of £200, i'm open to any ideas........ Discuss image
  • rachaelp
    rachaelp over 7 years ago +7
    Hi Andy, Noob questions are fine and people on this forum don't tend to assume anybody already knows all these things already. We all started somewhere So, I guess the first thing to ask is what will be…
  • Andy Betts
    Andy Betts over 7 years ago +5
    Hi Rachael, thanks for your reply. my intention initially is to just work on analogue guitar effects pedals, so I guess a 2 channel would suffice, however some of these analogue devices have IC's so would…
  • Andy Betts
    Andy Betts over 7 years ago in reply to rachaelp +5
    Most of the IC's used in pedal building are OP-Amps like theTL061 & LM741 , and delay chips like a MN3007, SAD1024. There are others obviously, but these seem to be the most common (with the exception…
  • rachaelp
    Hi Andy,
    Noob questions are fine and people on this forum don't tend to assume anybody already knows all these things already. We all started somewhere image
    So, I guess the first thing to ask is what will be your intended use for the oscilloscope? Will you be continuing to do mostly analog audio projects or are you going to branch out into other areas? It really does make all the difference to make sure you get what you really need. My next question, how much space do you have? Will you need to be moving it around often? Old analog scopes tend to be much larger and quite heavy (some are exceedingly heavy!) so if space is tight or you need portability you'd be better with a more modern scope. Do you need 2 or 4 channels? If you are doing mostly analog work then you can probably get away with 2 channels, if you are doing digital work then being able to look at 3 or 4 signals can be very useful when probing things like SPI busses. You can work with 2 channels but its easier with 4, but this will push your cost up.
    So here are a few things to consider:
    eBay is fine for test equipment but these days you don't always get the bargain you would hope for. Used test equipment seems to hold its price these days and its hard to find bargains sometimes.
    Here is an example of a possible reasonable option: https://www.ebay.co.uk/itm/Rigol-DS1052E-Digital-Storage-Oscilloscope-2-Channel-50MHz-Bandwidth-1GSa-s/253738588418?hash…
    Rigol and Siglent are probably the bet known budget brands for bench lab equipment. Brand new you might get a bottom of the range one of these for somewhere around the £250 to £300 mark. You might be able to pick up these second hand for less on eBay. I know with Rigol (and possible Siglent) if you look on EEVBlog you'll find guides which will show you how to enable all the licensed features and bandwidth of these scopes.
    Another option is the Picoscope range of USB oscilloscopes. There are other options around for this type but I think but some of them don't work so well. Picoscope seems like a good option and their software runs cross platform on Windows / macOS / Linux. You can get a 25MHz 2-channel Picoscope from CPC Farnell here: 2 Channel PC Oscilloscope with Arbitrary Waveform Generator and USB Interface - 25MHz - PICO TECHNOLOGY | CPC UK
    There are higher spec Picoscopes, take a look at their website and see their range. If you find more budget there are other options from them too but going to 4-channel or adding the MSO option takes you a lot over budget.
    If you could go a little over budget to say £250 then there is the Digilent Analog Discovery 2 which from the reviews I have seen seems really good. It's actually got a lot of instruments built into one, 30MHz 2 channel oscilloscope, 16-channel logic analyzer and pattern generator, Spectrum analyzer function, 2 channel arbitrary waveform generator. Again the software is cross platform and it's available from CPC Farnell: 2 Channel Analog Discovery 2 USB Oscilloscope - 30MHz - DIGILENT | CPC UK
    If you can help define a bit better what your needs are then we can probably help you narrow down your options a bit better and hopefully find you something which works for you.
    Best Regards,
    Rachael
    • Vote Up +7 Vote Down
  • Andy Betts
    my intention initially is to just work on analogue guitar effects pedals, so I guess a 2 channel would suffice, however some of these analogue devices have IC's so would a 4 channel be more preferable??
    I'm up for using a Windows based system, as that will likely run on my laptop and it'll be portable. So that might be a better option than lugging a heavy scope around.
    Cheers
    Andy
    • Vote Up +5 Vote Down
  • rachaelp
    rachaelp over 7 years ago in reply to Andy Betts
    So it depends what IC's they are. If they are ADC's and DAC's then you'll likely be dealing with I2S/TDM for the audio and SPI/I2C for the control of these. There will likely be an MCU or a small DSP possibly too. I'd say 4-channel or 2-channel + 16 bit MSO option would be a reasonable choice but that does put the price up quite a bit. The 2-channel + 16 bit MSO version of that Picoscope puts the price up to about £380. So at this point the Digilent Analog Discovery 2 is looking like a reasonable option except that the version on CPC Farnell is the basic unit without any of the add-ons so no adapters for scope probes and no scope probes etc. You can get the Pro version from Digilent but I don't know what the cost will be shipped to the UK including any customs charges: https://store.digilentinc.com/analog-discovery-2-pro-bundle/
    You could start with a basic 2-channel Picoscope (or something similar) or a 2-channel regular bench scope and see how you get on. You can usually work around the lack of additional channels if you need to and you'd probably be able to resell these if you wanted to upgrade.
    Best Regards,
    Rachael
  • Andy Betts
    Most of the IC's used in pedal building are OP-Amps like theTL061 & LM741 , and delay chips like a MN3007, SAD1024. There are others obviously, but these seem to be the most common (with the exception of the SAD1024 as that's discontinued)
    Cheers
    Andy
  • rachaelp
    Hi Andy,
    Right ok, so if it's all just analog stuff you are going to do, and your audio devices aren't going to involve any digital busses or anything like that then I would suggest you just go for a 2-channel scope. You don't need anything fast, the lowest spec Picoscope would probably do all you need, or get a second hand Rigol/Siglent 2-channel entry level device if you can find one.
    The 10MHz 2-channel Picoscope will cost you around £118 delivered from here: https://www.picotech.com/oscilloscope/2000/picoscope-2000-overview
    If you want to get a slightly higher bandwidth version you can get the 25MHz version I listed in my first post for around £170. If your budget is tight and you are definitely only going to be working in the audio band then this probably isn't necessary.
    Best Regards,
    Rachael
  • Andy Betts
    I think either of those will do. The 25MHz version is in budget and would allow redundancy for the future. I may be able to buy that through work as we have an account with Farnell and I wouldn't pay the VAT which is a plus point.
  • rachaelp
    If you can buy through work then maybe go to the main Farnell website rather than CPC: PICOSCOPE 2205A PICO TECHNOLOGY, USB Oscilloscope, PicoScope 2000 Series, 2 Channel
    Also bear in mind that if you got an entry level Rigol you'd be able to update it to (I think) 100MHz bandwidth. But the starting price point is a lot higher and not in your current stated budget. So I think the Picoscope is still probably still the best option in my opinion. Disclaimer, I don't own a Picoscope and haven't used the software so I don't have first hand experience with these but from what I have seen/read they are good for the price.
    Best Regards,
    Rachael
    michaelkellett over 7 years ago in reply to rachaelp
    I do own a Pico scope, and a Rigol somewhat up a step from the one Andy can afford, neither of these is my main scope, both were bought for particular applications (the Rigol for use in places where the insurance company wouldn't allow the LeCroy to g !).
    I think the Pico stuff that I've seen is pretty good - and I'm very happy with the one I have (5444B).
    At Andy's price level not forking out for a screen and front panel makes a big difference to the quality of works that you get.
    dougw over 7 years ago
    I like the price/performance of PC scopes and that prompted me to buy several but I ended up never using them - the performance is okay but it just seems too cumbersome to connect them up and boot the software.
    Even before I had better stand-alone scopes, these scopes were a last resort.
    The concept keeps evolving and I am still intrigued, but I might try one of the newer touch screen devices like a LabNation to see if they fit into a workflow better.
  • Fred27
    Fred27 over 7 years ago
    Generally, whenever this question is asked the answer is "get a Rigol DS1054Z". It's the go-to budget 'scope. However it is a little out of your £200 price range. If you can stretch to it then I think it gives much better price/performance than the cheaper options that Rachael recommended. If you really are limited to £200 then Rachael's right.
