Ask an Expert Forum Inefficiencies in Hardware Bring-up Discussion
  • Replies 31 replies
  • Subscribers 306 subscribers
  • Views 3614 views
  • testing
  • hardware development
  • eda tools
  • pcb
  • debugging
  • validation
  • pcb design
See a helpful answer?
derail
derail over 7 years ago
Hello all,
I am an electrical engineering undergraduate currently in the process of starting my senior design project (capstone) with an idea based around solving test and debug inefficiencies in the hardware bring-up realm.
I’d like to start a conversation about what really grinds your gears at your workplace, or on your downtime at home, while designing, testing and validating new board designs. Any feedback is greatly appreciated!
To get things started here are some of the questions I really want to be discussed:
  • What type of information (and medium) do you have about a board while you are testing it?
  • Through your experience, what points in your testing workflow do you see as inefficient?
  • What is the biggest problem you’ve faced while performing bring-up on a new PCB?
  • What PCB design software did you use (KiCAD, Altium, Eagle, etc)?
  • What parts of your PCB design software did you find most helpful with bringing up a new board?
Thank you in advance to anyone that can provide feedback on this subject as it will really help my capstone team narrow what to build and help validate some of our potential ideas.
Cheers,
Darryl
    jw0752 over 7 years ago in reply to michaelkellett +7
    Hi Michael, I do not often print the replies to posts but your reply was an exception. It was only after I printed it and reread it on paper that I caught the reference to the Non-Slip probes. I have never…
    dougw over 7 years ago +6
    This is a big subject. Usually it all starts with power rail verification but one issue I come across more than I'd like is validation of non-standard connector pinouts. CAD tools may have no way of checking…
    michaelkellett over 7 years ago +6
    That's a very ambitious undergraduate project. Experience is what sorts out the good from the bad in this area. The biggest problem you get is a dead short across the power rails, closely followed by high…
  • rusgray
    rusgray over 7 years ago
    Everything I can get my hands on. At minimum, a printed copy (on the largest paper that is reasonable) of the schematics and a computer with the PCB layout available (either as an EDA tool or as Gerbers in a viewer.)
    In my experience, the testing/bringup process is inherently inefficient, because you don't know what you don't know. Following good procedures can help reduce some of the inefficiencies, but there's really no way beyond that to speed things up other than experience, and the experience comes from painful hours and days spent stuck on a problem that turns out to be trivial.
    Connectors having incorrect pinouts. It's the worst when this happens with an external power connector.
    I'm most comfortable with EAGLE.
    The most useful EDA features for bringup are the ability to highlight individual nets/signals and the ability to snap the schematic view to a specified component, even if it's not on the schematic sheet that is currently in focus.
  • derail
    derail over 7 years ago in reply to rusgray
    Thank you for the feedback Russell! The incorrect pinout on connectors is for sure looking like one of the most common problems faced. May I ask why you decide to print a copy of your schematics instead of just using the schematic viewer on your computer in parallel with the PCB layout?
    dougw over 7 years ago in reply to derail
    I use printed schematics and artwork as well - because I can clip them above the workspace. There is no room for a monitor at this time - too much other instrumentation.
    michaelkellett over 7 years ago in reply to dougw
    Same here, the monitor is usually busy enough, printed schematics are also good for quick annotation.
