Ask an Expert Forum Hall Effect Sensor Recommendation?
  • Subscribers 323 subscribers
  • Views 1058 views
  • hall effect sensor
  • basic electronics
See a helpful answer?
Sean_Miller
Sean_Miller over 7 years ago
Does anyone have guidance for a hall sensor for the following case:
I need to power a circuit when a magnet is removed.  It is to detect when a door or window has been opened.
I have a great working circuit for a Normally Closed reed switch, but since the reed switch is mechanical, it has proven unreliable.  The reed switch pulls a P-MOSFET low to trigger power to my microcontroller, which then latches the power in by N-MOSFET...should the door or window shut.
I'm confused by Open Drain & Open Collector type hall effect sensors.  Does anyone have guidance for a replacement for the reed switch?  I'm operating on 3.3V.
Sean
    dougw over 7 years ago +3
    Allegro A3213EUA-T Allegro A3213EUA-T is a low voltage Hall switch that would work, but the gate would need a pull down resistor and the switch would need to connect to 3.3V to get the polarity you want…
  • Sean_Miller
    Sean_Miller over 7 years ago in reply to dougw +3
    The datasheet looks dead on. As fast as you answered, I'm torn between I wasted 5 hours over three evenings researching, or glad I learned a little on the journey. My wife would say the former. :-) Thanks…
  • colporteur
    colporteur over 7 years ago in reply to Sean_Miller +3
    Do not be discourage by your investment of 5 hours. It would be ideal if we could hand off our experience to those coming after us so they don't have to invest as much. Unfortunately, time is a requirement…
    Allegro A3213EUA-TAllegro A3213EUA-T is a low voltage Hall switch that would work, but the gate would need a pull down resistor and the switch would need to connect to 3.3V to get the polarity you want.
  • Sean_Miller
    Thanks so much!
    Sean
  • colporteur
    Do not be discourage by your investment of 5 hours.  It would be ideal if we could hand off our experience to those coming after us so they don't have to invest as much. Unfortunately, time is a requirement to gain experience. Once obtained it can't be taken from you.
    Based on my 37 years in technology the knowledge from the 5 hour experiences is sometimes transferable and permits us to reduce the time we invest to gain other experience.
    Sean
