Industrial Automation
Blog Cooling System in China Cools the Air Around Apartment Buildings
  • Date Created: 14 Jul 2026 7:35 PM Date Created
  • Views 1516 views
  • infrastructure
  • structure
  • building
  • hmi
  • human
  • life
  • cooling
14 Jul 2026
China’s rooftop rain system releases water mist to cool the air on hot days. (Image Credit: Reddit)
It’s hard to believe this is real. But, China is deploying some pretty cool technology. Literally. If there’s hot weather in the area, air conditioning can shield you from the heat. Recently, China came up with an alternative cool-down method called rooftop rain that lowers the air temperature for those living in high-rise apartment buildings.
The system, which uses evaporative cooling, has already been deployed in Yuncheng, Shanxi, atop tall apartment complexes. Intended for extremely hot days, the high-pressure nozzles spray a fine water mist into the surrounding air.
The heat allows the droplets to evaporate before they can reach the ground. If the air is too cool or humid, the mist will evaporate too slowly and fall below. While evaporating, these droplets carry away heat to reduce the air temperature by as much as 46°F.
People in online communities like Reddit and Instagram have noticed this system. And they’ve asked why this method isn’t being used all over the world. With the intense heat waves hitting Europe and North America, expanding its use seems like the right idea. However, it’s far more complex to consider.
It’s an intriguing concept, but we still don’t fully understand this rooftop rain system. And there are questions about how well it could be scaled up and how much water it would need. Would mineral deposits block the nozzles? And would the system reduce the temperature inside the apartment buildings for the residents? Although there isn’t much information about the system, its deployment in Chinese cities suggests it offers some noteworthy benefits.
    DAB 3 months ago
    Makes sense. Same principle as an air conditioner just using the heat absorption capability of water.
    Cheap, easy to install and very effective.
    DAB 3 months ago
