Industrial Automation
Blog Ikea Kallax Insert with Door as DIN rail housing
  • Date Created: 23 Nov 2024 6:11 PM Date Created
  • Views 1969 views
  • Likes 14 likes
  • industrial
  • din
  • ikea
23 Nov 2024
Ikea Kallax is a modular storage range. Used in houses and offices. I'm going to turn their "Insert With Door" into an industrial DIN plug-in. It will be able to hold automation and compute devices in an office-like environment.
An insert is inexpensive, about 15 €. It consists of a door, and 3 sides of enforced cardboard. These sides are strong enough to hold DIN rails. Easy to drill holes in, and customise if needed.
My first design will only put rails to the back board. DIN compliant, with the correct space between the rails. I'll use it to house a network hub, power provisioning, and an SBC gateway device. Maybe I'll add a LoRaWan device too, if I find a good solution to route the antenna outside...
It would also be a good solution for smart home appliances. Not those that you usually put in your main utilities cabinet. But the low power smart ones.
This setup is not intended for projects where you need safety, high power or fire-resilience. It's intended for the low power smart part. Let's see if it can serve that purpose ... It would allow for an easy experimental setup in your office. That you can reuse - or discard, when appropriate
  • bidrohini
    bidrohini over 1 year ago
    You can use a hole saw or drill to create precise openings for power and networking cables.
    genebren over 1 year ago
    Very interesting.  I look forward to seeing how this works out for you.
    DAB over 1 year ago
    Interesting idea if you need a simple or temporary enclosure.
    shabaz over 1 year ago
    I have those too. I'm sure I even have a spare one lying around when I wasn't sure how many of those inserts I needed.
    It will be interesting seeing how you adapt it. It's indeed a nice thing to reuse, and since IKEA parts are globally easily available, it is simple for others to replicate.
