Industrial Automation
Blog Infineon SLx9670 Trusted Platform Module (TPM) on Debian 11 "bullseye" - part2: Trusted Software Stack (tss)
  • Date Created: 12 Nov 2021 12:56 PM Date Created
  • Views 1703 views
  • infineon
  • slb9670
  • tss
  • trusted_platform_module
  • trusted_software_stack
  • tpm
12 Nov 2021
The latest Raspberry OS at the time of writing this post is Debian 11 "bullseye".
I'm checking how the Infineon TPM IC behaves under that version.
In this 2nd part, I handle the TSS (Trusted Software Stack) software libraries and utilities.
It's not a deep dive into the subject. I want to check if I can still build and use the stack with Debian 11.
Let's now check the installations. If they "just worked", I put a Y in the table below.
When there were issues or failures, I'll elaborate below the table.
I've tried using the latest version of any package - for Debian 11. I specify when I took a different path.
This will be a WIP post until I've completed the exercise. I'll come back and edit as I go along.
(ignore, solved: Don't try this yet. I've come to a state where the TPM doesn't work anymore in this configuration.)
module version success
tpm2-tss master,
3.1.0-86-g7fde6043,
taken on 11-dec-2021
Y
tpm2-tabrmd
master,
commit 41fd797112f0aa7b38a34c6e80b63d311b2ff76f,
Y
tpm2-tools
master,
commit 7b6600d3214dd45531bdb53d5f2510404c31fd6b,
Y*1
tpm2-tss-engine master,
commit ee470c85583d167305a9a04e73e2c3368e95530b,
Y*2
cryptsetup todo
tpm2-pkcs11 todo
1: pre-steps complain that package python-yaml has no install candidate. It didn't give issues.
2: at this point, everything stopped working. I'm starting again.
Side stories
tpm2-tss: running the unit and hardware tests
I haven't done this in the road test. It was listed a s a stretch goal. Time to pay up.
Instructions are on Infineon's github. IO configured unit tests and integration tests, with the Infineon hardware as backend.
There are 3 types of test: mandatory, optional and destructive. The destructive option invalidates the IC forever - as per spec. Obviously I'm not executing that suite Expressionless.
The test suite requires root powers to talk to the device. So I changed to root, while keeping the pi user environment settings:
Prepare and run:
sudo -E -s
./configure --enable-unit --enable-integration --with-device=/dev/tpm0 --with-devicetests="mandatory,optional"
Running the suite takes a while. I'm still root at this time.
The check-device make target takes care that only one process runs at the same time. The suite fails when multiple processes run in parallel.
make check-device
If you want to run them again, with the same configuration, just run the make command again.
If you want to use another config (software simulation instead of using the IC, skip unit tests, only run mandatory test suite, ...) you can rerun configure with the requested options. Then rerun make.
Results:
unit test, integration, mandatory and optional
Test log:
Fullscreen test-suite.log Download
   tpm2-tss 3.1.0-86-g7fde6043: ./test-suite.log
# TOTAL: 195
# PASS:  133
# SKIP:  12
# XFAIL: 0
# FAIL:  5
# XPASS: 0
# ERROR: 45
.. contents:: :depth: 2
SKIP: test/integration/esys-act-set-timeout
TPM20TEST_TCTI_NAME=device
TPM20TEST_DEVICE_FILE=/dev/tpm0
TPM20TEST_SOCKET_ADDRESS=
TPM20TEST_SOCKET_PORT=
TPM20TEST_TCTI=device:host=,port=
Execute the test script
WARNING:esys:src/tss2-esys/api/Esys_ACT_SetTimeout.c:292:Esys_ACT_SetTimeout_Finish() Received TPM Error
ERROR:esys:src/tss2-esys/api/Esys_ACT_SetTimeout.c:102:Esys_ACT_SetTimeout() Esys Finish ErrorCode (0x00000143)
ERROR:test:test/integration/esys-act-set-timeout.int.c:65:test_esys_act_set_timeout() Error: Clear ErrorCode (0x00000143)
Script returned 77
failed to stop daemon, no pid file: /home/pi/tssSetup/tpm2-tss/test/integration/esys-act-set-timeout.int_simulator.pid
SKIP test/integration/esys-act-set-timeout.int (exit status: 77)
SKIP: test/integration/esys-certifyX509
WARNING:esys:src/tss2-esys/api/Esys_CertifyX509.c:345:Esys_CertifyX509_Finish() Received TPM Error
ERROR:esys:src/tss2-esys/api/Esys_CertifyX509.c:112:Esys_CertifyX509() Esys Finish ErrorCode (0x00000143)
ERROR:test:test/integration/esys-certifyX509.int.c:183:test_esys_certifyx509() Error: CertifyX509 ErrorCode (0x00000143)
Script returned 77
failed to stop daemon, no pid file: /home/pi/tssSetup/tpm2-tss/test/integration/esys-certifyX509.int_simulator.pid
SKIP test/integration/esys-certifyX509.int (exit status: 77)
FAIL: test/integration/esys-get-capability-act
WARNING:esys:src/tss2-esys/api/Esys_GetCapability.c:303:Esys_GetCapability_Finish() Received TPM Error
ERROR:esys:src/tss2-esys/api/Esys_GetCapability.c:107:Esys_GetCapability() Esys Finish ErrorCode (0x000001c4)
ERROR:test:test/integration/esys-get-capability-act.int.c:39:test_esys_get_capability_act() Error esys get capability ErrorCode (0x000001c4)
Script returned 1
failed to stop daemon, no pid file: /home/pi/tssSetup/tpm2-tss/test/integration/esys-get-capability-act.int_simulator.pid
FAIL test/integration/esys-get-capability-act.int (exit status: 1)
SKIP: test/integration/esys-audit
WARNING:esys:src/tss2-esys/api/Esys_GetCommandAuditDigest.c:329:Esys_GetCommandAuditDigest_Finish() Received TPM Error
ERROR:esys:src/tss2-esys/api/Esys_GetCommandAuditDigest.c:108:Esys_GetCommandAuditDigest() Esys Finish ErrorCode (0x00000143)
WARNING:test:test/integration/esys-audit.int.c:196:test_esys_audit() Command TPM2_GetCommandAuditDigest not supported by TPM.
Script returned 77
failed to stop daemon, no pid file: /home/pi/tssSetup/tpm2-tss/test/integration/esys-audit.int_simulator.pid
SKIP test/integration/esys-audit.int (exit status: 77)
SKIP: test/integration/esys-duplicate
WARNING:esys:src/tss2-esys/api/Esys_Rewrap.c:331:Esys_Rewrap_Finish() Received TPM Error
ERROR:esys:src/tss2-esys/api/Esys_Rewrap.c:109:Esys_Rewrap() Esys Finish ErrorCode (0x00000143)
WARNING:test:test/integration/esys-duplicate.int.c:410:test_esys_duplicate() Command TPM2_Rewrap not supported by TPM.
Script returned 77
failed to stop daemon, no pid file: /home/pi/tssSetup/tpm2-tss/test/integration/esys-duplicate.int_simulator.pid
SKIP test/integration/esys-duplicate.int (exit status: 77)
SKIP: test/integration/esys-encrypt-decrypt
WARNING:esys:src/tss2-esys/api/Esys_EncryptDecrypt.c:328:Esys_EncryptDecrypt_Finish() Received TPM Error
ERROR:esys:src/tss2-esys/api/Esys_EncryptDecrypt.c:110:Esys_EncryptDecrypt() Esys Finish ErrorCode (0x00000143)
WARNING:test:test/integration/esys-encrypt-decrypt.int.c:278:test_esys_encrypt_decrypt() Command TPM2_EncryptDecrypt not supported by TPM.
Script returned 77
failed to stop daemon, no pid file: /home/pi/tssSetup/tpm2-tss/test/integration/esys-encrypt-decrypt.int_simulator.pid
SKIP test/integration/esys-encrypt-decrypt.int (exit status: 77)
SKIP: test/integration/esys-encrypt-decrypt2
WARNING:esys:src/tss2-esys/api/Esys_EncryptDecrypt2.c:322:Esys_EncryptDecrypt2_Finish() Received TPM Error
ERROR:esys:src/tss2-esys/api/Esys_EncryptDecrypt2.c:107:Esys_EncryptDecrypt2() Esys Finish ErrorCode (0x00000143)
Script returned 77
failed to stop daemon, no pid file: /home/pi/tssSetup/tpm2-tss/test/integration/esys-encrypt-decrypt2.int_simulator.pid
SKIP test/integration/esys-encrypt-decrypt2.int (exit status: 77)
SKIP: test/integration/esys-pcr-auth-value
WARNING:esys:src/tss2-esys/api/Esys_PCR_SetAuthValue.c:287:Esys_PCR_SetAuthValue_Finish() Received TPM Error
ERROR:esys:src/tss2-esys/api/Esys_PCR_SetAuthValue.c:98:Esys_PCR_SetAuthValue() Esys Finish ErrorCode (0x00000143)
WARNING:test:test/integration/esys-pcr-auth-value.int.c:66:test_esys_pcr_auth_value() Command TPM2_PCR_SetAuthValue not supported by TPM.
Script returned 77
failed to stop daemon, no pid file: /home/pi/tssSetup/tpm2-tss/test/integration/esys-pcr-auth-value.int_simulator.pid
SKIP test/integration/esys-pcr-auth-value.int (exit status: 77)
SKIP: test/integration/esys-policy-physical-presence-opt
WARNING:esys:src/tss2-esys/api/Esys_PolicyPhysicalPresence.c:283:Esys_PolicyPhysicalPresence_Finish() Received TPM Error
ERROR:esys:src/tss2-esys/api/Esys_PolicyPhysicalPresence.c:98:Esys_PolicyPhysicalPresence() Esys Finish ErrorCode (0x00000143)
WARNING:test:test/integration/esys-policy-physical-presence-opt.int.c:117:test_esys_policy_physical_presence_opt() Command TPM2_PolicyPhysicalPresence  not supported by TPM.
Script returned 77
failed to stop daemon, no pid file: /home/pi/tssSetup/tpm2-tss/test/integration/esys-policy-physical-presence-opt.int_simulator.pid
SKIP test/integration/esys-policy-physical-presence-opt.int (exit status: 77)
SKIP: test/integration/esys-pp-commands
WARNING:esys:src/tss2-esys/api/Esys_PP_Commands.c:301:Esys_PP_Commands_Finish() Received TPM Error
ERROR:esys:src/tss2-esys/api/Esys_PP_Commands.c:104:Esys_PP_Commands() Esys Finish ErrorCode (0x00000143)
WARNING:test:test/integration/esys-pp-commands.int.c:56:test_esys_pp_commands() Command TPM2_PP_Commands not supported by TPM.
ERROR:test:test/integration/esys-pp-commands.int.c:70:test_esys_pp_commands() Error: PP_Commands ErrorCode (0x00000143)
Script returned 77
failed to stop daemon, no pid file: /home/pi/tssSetup/tpm2-tss/test/integration/esys-pp-commands.int_simulator.pid
SKIP test/integration/esys-pp-commands.int (exit status: 77)
SKIP: test/integration/esys-zgen-2phase
WARNING:esys:src/tss2-esys/api/Esys_EC_Ephemeral.c:283:Esys_EC_Ephemeral_Finish() Received TPM Error
ERROR:esys:src/tss2-esys/api/Esys_EC_Ephemeral.c:98:Esys_EC_Ephemeral() Esys Finish ErrorCode (0x00000143)
WARNING:test:test/integration/esys-zgen-2phase.int.c:166:test_esys_zgen_2phase() Command TPM2_Ephemeral not supported by TPM.
ERROR:test:test/integration/esys-zgen-2phase.int.c:219:test_esys_zgen_2phase()
Error Code: 143
Script returned 77
failed to stop daemon, no pid file: /home/pi/tssSetup/tpm2-tss/test/integration/esys-zgen-2phase.int_simulator.pid
SKIP test/integration/esys-zgen-2phase.int (exit status: 77)
SKIP: test/integration/fapi-data-crypt
TPM20TEST_TCTI=device:/dev/tpm0
info:test:test/integration/main-fapi.c:341:init_fapi() Using config:
     "profile_name": "P_ECC",
     "profile_dir": "./test/data/fapi/",
     "user_dir": "/tmp/fapi_tmpdir.jT3DD0/user/dir",
     "system_dir": "/tmp/fapi_tmpdir.jT3DD0/system_dir",
     "system_pcrs" : [],
     "log_dir" : "/tmp/fapi_tmpdir.jT3DD0",
     "tcti": "device:/dev/tpm0",
WARNING:fapi:src/tss2-fapi/ifapi_io.c:340:ifapi_io_check_create_dir() Directory /tmp/fapi_tmpdir.jT3DD0/user/dir does not exist, creating
WARNING:fapi:src/tss2-fapi/ifapi_io.c:340:ifapi_io_check_create_dir() Directory /tmp/fapi_tmpdir.jT3DD0/system_dir/policy does not exist, creating
ERROR:fapi:src/tss2-fapi/api/Fapi_Encrypt.c:332:Fapi_Encrypt_Finish() ErrorCode (0x00060002) ECC Encryption not yet supported
ERROR:fapi:src/tss2-fapi/api/Fapi_Encrypt.c:126:Fapi_Encrypt() ErrorCode (0x00060002) Data_Encrypt
ERROR:fapi:src/tss2-fapi/api/Fapi_Delete.c:405:Fapi_Delete_Async() ErrorCode (0x00060034) FAPI not provisioned.
ERROR:fapi:src/tss2-fapi/api/Fapi_Delete.c:313:Fapi_Delete() ErrorCode (0x00060034) Entity_Delete
info:test:test/integration/main-fapi.c:432:main() Test returned 77
Script returned 77
SKIP test/integration/fapi-data-crypt.fint (exit status: 77)
SKIP: test/integration/fapi-data-crypt-persistent
     "user_dir": "/tmp/fapi_tmpdir.Dsny2F/user/dir",
     "system_dir": "/tmp/fapi_tmpdir.Dsny2F/system_dir",
     "system_pcrs" : [],
     "log_dir" : "/tmp/fapi_tmpdir.Dsny2F",
WARNING:fapi:src/tss2-fapi/ifapi_io.c:340:ifapi_io_check_create_dir() Directory /tmp/fapi_tmpdir.Dsny2F/user/dir does not exist, creating
WARNING:fapi:src/tss2-fapi/ifapi_io.c:340:ifapi_io_check_create_dir() Directory /tmp/fapi_tmpdir.Dsny2F/system_dir/policy does not exist, creating
WARNING:esys:src/tss2-esys/api/Esys_FlushContext.c:234:Esys_FlushContext_Finish() Received TPM Error
ERROR:esys:src/tss2-esys/api/Esys_FlushContext.c:89:Esys_FlushContext() Esys Finish ErrorCode (0x000001c4)
Script returned 77
SKIP test/integration/fapi-data-crypt-persistent.fint (exit status: 77)
FAIL: test/integration/fapi-data-crypt-rsa
     "profile_name": "P_RSA",
     "user_dir": "/tmp/fapi_tmpdir.PWfnpm/user/dir",
     "system_dir": "/tmp/fapi_tmpdir.PWfnpm/system_dir",
     "system_pcrs" : [],
     "log_dir" : "/tmp/fapi_tmpdir.PWfnpm",
WARNING:fapi:src/tss2-fapi/ifapi_io.c:340:ifapi_io_check_create_dir() Directory /tmp/fapi_tmpdir.PWfnpm/user/dir does not exist, creating
WARNING:fapi:src/tss2-fapi/ifapi_io.c:340:ifapi_io_check_create_dir() Directory /tmp/fapi_tmpdir.PWfnpm/system_dir/policy does not exist, creating
ERROR:fapi:src/tss2-fapi/api/Fapi_Provision.c:999:Fapi_Provision_Finish() ErrorCode (0x0006000b) SRK persistent handle already defined
WARNING:fapi:src/tss2-fapi/ifapi_io.c:428:ifapi_io_remove_directories() Removing: /tmp/fapi_tmpdir.PWfnpm/system_dir/P_RSA/HE/EK/object.json
ERROR:fapi:src/tss2-fapi/api/Fapi_Provision.c:168:Fapi_Provision() ErrorCode (0x0006000b) Provision
ERROR:test:test/integration/fapi-data-crypt.int.c:212:test_fapi_data_crypt() Error Fapi_Provision ErrorCode (0x0006000b)
info:test:test/integration/main-fapi.c:432:main() Test returned 1
Script returned 1
FAIL test/integration/fapi-data-crypt-rsa.fint (exit status: 1)
FAIL: test/integration/fapi-data-crypt-rsa-persistent
     "user_dir": "/tmp/fapi_tmpdir.mJoI4w/user/dir",
     "system_dir": "/tmp/fapi_tmpdir.mJoI4w/system_dir",
     "system_pcrs" : [],
     "log_dir" : "/tmp/fapi_tmpdir.mJoI4w",
WARNING:fapi:src/tss2-fapi/ifapi_io.c:340:ifapi_io_check_create_dir() Directory /tmp/fapi_tmpdir.mJoI4w/user/dir does not exist, creating
WARNING:fapi:src/tss2-fapi/ifapi_io.c:340:ifapi_io_check_create_dir() Directory /tmp/fapi_tmpdir.mJoI4w/system_dir/policy does not exist, creating
WARNING:fapi:src/tss2-fapi/ifapi_io.c:428:ifapi_io_remove_directories() Removing: /tmp/fapi_tmpdir.mJoI4w/system_dir/P_RSA/HE/EK/object.json
Script returned 1
FAIL test/integration/fapi-data-crypt-rsa-persistent.fint (exit status: 1)
FAIL: test/integration/fapi-get-esys-blobs
     "user_dir": "/tmp/fapi_tmpdir.SuDsrZ/user/dir",
     "system_dir": "/tmp/fapi_tmpdir.SuDsrZ/system_dir",
     "system_pcrs" : [],
     "log_dir" : "/tmp/fapi_tmpdir.SuDsrZ",
WARNING:fapi:src/tss2-fapi/ifapi_io.c:340:ifapi_io_check_create_dir() Directory /tmp/fapi_tmpdir.SuDsrZ/user/dir does not exist, creating
WARNING:fapi:src/tss2-fapi/ifapi_io.c:340:ifapi_io_check_create_dir() Directory /tmp/fapi_tmpdir.SuDsrZ/system_dir/policy does not exist, creating
ERROR:test:test/integration/fapi-get-esys-blobs.int.c:198:test_fapi_get_esys_blobs() Invalid type
Script returned 1
FAIL test/integration/fapi-get-esys-blobs.fint (exit status: 1)
FAIL: test/integration/fapi-key-create2-sign
     "user_dir": "/tmp/fapi_tmpdir.mmPoh0/user/dir",
     "system_dir": "/tmp/fapi_tmpdir.mmPoh0/system_dir",
     "system_pcrs" : [],
     "log_dir" : "/tmp/fapi_tmpdir.mmPoh0",
WARNING:fapi:src/tss2-fapi/ifapi_io.c:340:ifapi_io_check_create_dir() Directory /tmp/fapi_tmpdir.mmPoh0/user/dir does not exist, creating
WARNING:fapi:src/tss2-fapi/ifapi_io.c:340:ifapi_io_check_create_dir() Directory /tmp/fapi_tmpdir.mmPoh0/system_dir/policy does not exist, creating
WARNING:esys:src/tss2-esys/api/Esys_Create.c:398:Esys_Create_Finish() Received TPM Error
ERROR:fapi:src/tss2-fapi/fapi_util.c:3437:ifapi_key_create() ErrorCode (0x0000018a) Key create finish
ERROR:fapi:src/tss2-fapi/api/Fapi_CreateKey.c:283:Fapi_CreateKey_Finish() Key create ErrorCode (0x0000018a)
ERROR:fapi:src/tss2-fapi/api/Fapi_CreateKey.c:116:Fapi_CreateKey() ErrorCode (0x0000018a) Key_Create
WARNING:esys:src/tss2-esys/api/Esys_PolicyPCR.c:288:Esys_PolicyPCR_Finish() Received TPM Error
ERROR:fapi:src/tss2-fapi/ifapi_policy_execute.c:221:execute_policy_pcr() ErrorCode (0x000001c4) Execute PolicyPCR_Finish.
ERROR:fapi:src/tss2-fapi/ifapi_policy_execute.c:1490:execute_policy_element() ErrorCode (0x000001c4) Execute policy pcr
ERROR:fapi:src/tss2-fapi/ifapi_policy_execute.c:1722:ifapi_policyeval_execute() Execute policy. ErrorCode (0x000001c4)
ERROR:fapi:src/tss2-fapi/ifapi_policyutil_execute.c:296:ifapi_policyutil_execute() Execute policy. ErrorCode (0x000001c4)
ERROR:fapi:src/tss2-fapi/ifapi_policy_callbacks.c:1273:ifapi_exec_auth_policy() Execute policy. ErrorCode (0x000001c4)
ERROR:fapi:src/tss2-fapi/ifapi_policy_execute.c:614:execute_policy_authorize() Execute authorized policy. ErrorCode (0x000001c4)
ERROR:fapi:src/tss2-fapi/ifapi_policy_execute.c:1514:execute_policy_element() ErrorCode (0x000001c4) Execute policy authorize
ERROR:esys:src/tss2-esys/esys_iutil.c:1096:esys_GetResourceObject() Error: Esys handle does not exist (70018).
ERROR:esys:src/tss2-esys/api/Esys_FlushContext.c:138:Esys_FlushContext_Async() flushHandle unknown. ErrorCode (0x00070018)
ERROR:esys:src/tss2-esys/api/Esys_FlushContext.c:66:Esys_FlushContext() Error in async function ErrorCode (0x00070018)
ERROR:fapi:src/tss2-fapi/fapi_util.c:2115:ifapi_authorize_object() Execute policy. ErrorCode (0x000001c4)
ERROR:fapi:src/tss2-fapi/fapi_util.c:1909:ifapi_load_key_finish() ErrorCode (0x000001c4) Authorize key.
ERROR:fapi:src/tss2-fapi/fapi_util.c:1717:ifapi_load_keys_finish() Load keys ErrorCode (0x000001c4)
ERROR:fapi:src/tss2-fapi/fapi_util.c:2730:ifapi_load_key() ErrorCode (0x000001c4)  Load key.
ERROR:fapi:src/tss2-fapi/api/Fapi_Sign.c:288:Fapi_Sign_Finish() Fapi load key. ErrorCode (0x000001c4)
ERROR:fapi:src/tss2-fapi/api/Fapi_Sign.c:130:Fapi_Sign() ErrorCode (0x000001c4) Key_Sign
info:test:test/integration/main-fapi.c:432:main() Test returned 0
Script returned 0
TPM changed state during test
State before (/home/pi/tssSetup/tpm2-tss/test/integration/fapi-key-create2-sign.fint_state1):
cap0: 0000000500000002000403ffffff000b03ffffff00
cap1: 0000000100000018000000000000000100000002000000030000000400000005000000060000000700000008000000090000000a0000000b0000000c0000000d0000000e0000000f000000100000001100000012000000130000001400000015000000160000001700
cap2: 000000010000000000
cap3: 000000010000000000
cap4: 000000010000000000
cap5: 000000010000000381000001810001008101000100
cap6: 000000010000000201c0000201c0000a00
State after (/home/pi/tssSetup/tpm2-tss/test/integration/fapi-key-create2-sign.fint_state2):
cap4: 00000001000000018000000200
FAIL test/integration/fapi-key-create2-sign.fint (exit status: 1)
ERROR: test/integration/fapi-key-create-null-key-sign
ERROR:test:test/helper/tpm_transientempty.c:54:main() TPM contains transient entries
ERROR:test:test/helper/tpm_transientempty.c:56:main() Handle 80000002
TPM transient area not empty => skipping
ERROR test/integration/fapi-key-create-null-key-sign.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-sign-persistent-key
ERROR test/integration/fapi-key-create-sign-persistent-key.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-sign-password-provision
ERROR test/integration/fapi-key-create-sign-password-provision.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-sign-rsa
ERROR test/integration/fapi-key-create-sign-rsa.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-policy-authorize-sign
ERROR test/integration/fapi-key-create-policy-authorize-sign.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-policy-authorize-rsa-pem-sign
ERROR test/integration/fapi-key-create-policy-authorize-rsa-pem-sign.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-policy-authorize-ecc-pem-sign
ERROR test/integration/fapi-key-create-policy-authorize-ecc-pem-sign.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-policy-authorize-sign-rsa
ERROR test/integration/fapi-key-create-policy-authorize-sign-rsa.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-policy-authorize-nv-sign
ERROR test/integration/fapi-key-create-policy-authorize-nv-sign.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-policy-secret-nv-sign
ERROR test/integration/fapi-key-create-policy-secret-nv-sign.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-policy-pcr-sign
ERROR test/integration/fapi-key-create-policy-pcr-sign.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-policy-signed
ERROR test/integration/fapi-key-create-policy-signed.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-policy-signed-ecc
ERROR test/integration/fapi-key-create-policy-signed-ecc.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-policy-nv-sign
ERROR test/integration/fapi-key-create-policy-nv-sign.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-policy-nv-counter-sign
ERROR test/integration/fapi-key-create-policy-nv-counter-sign.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-policy-or-sign
ERROR test/integration/fapi-key-create-policy-or-sign.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-policy-password-sign
ERROR test/integration/fapi-key-create-policy-password-sign.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-policy-countertimer-sign
ERROR test/integration/fapi-key-create-policy-countertimer-sign.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-policy-physical-presence-sign
ERROR test/integration/fapi-key-create-policy-physical-presence-sign.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-policy-locality-sign
ERROR test/integration/fapi-key-create-policy-locality-sign.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-policy-command-code-sign
ERROR test/integration/fapi-key-create-policy-command-code-sign.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-policy-auth-value-sign
ERROR test/integration/fapi-key-create-policy-auth-value-sign.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-ckda-sign
ERROR test/integration/fapi-key-create-ckda-sign.fint (exit status: 99)
ERROR: test/integration/fapi-key-change-auth
ERROR test/integration/fapi-key-change-auth.fint (exit status: 99)
ERROR test/integration/fapi-key-create-sign-persistent.fint (exit status: 99)
ERROR test/integration/fapi-key-create-sign-password.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-ckda-sign-password
ERROR test/integration/fapi-key-create-ckda-sign-password.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-sign-password-da
ERROR test/integration/fapi-key-create-sign-password-da.fint (exit status: 99)
ERROR: test/integration/fapi-key-create-ckda-sign-password-da
ERROR test/integration/fapi-key-create-ckda-sign-password-da.fint (exit status: 99)
ERROR: test/integration/fapi-nv-authorizenv-cphash
ERROR test/integration/fapi-nv-authorizenv-cphash.fint (exit status: 99)
ERROR: test/integration/fapi-nv-ordinary
ERROR test/integration/fapi-nv-ordinary.fint (exit status: 99)
ERROR: test/integration/fapi-nv-written-policy
ERROR test/integration/fapi-nv-written-policy.fint (exit status: 99)
ERROR: test/integration/fapi-nv-extend
ERROR test/integration/fapi-nv-extend.fint (exit status: 99)
ERROR: test/integration/fapi-nv-increment
ERROR test/integration/fapi-nv-increment.fint (exit status: 99)
ERROR: test/integration/fapi-nv-set-bits
ERROR test/integration/fapi-nv-set-bits.fint (exit status: 99)
ERROR: test/integration/fapi-pcr-test
ERROR test/integration/fapi-pcr-test.fint (exit status: 99)
ERROR: test/integration/fapi-quote
ERROR test/integration/fapi-quote.fint (exit status: 99)
ERROR: test/integration/fapi-quote-with-primary
ERROR test/integration/fapi-quote-with-primary.fint (exit status: 99)
ERROR: test/integration/fapi-quote-rsa
ERROR test/integration/fapi-quote-rsa.fint (exit status: 99)
ERROR: test/integration/fapi-policy-or-nv-read-write
ERROR test/integration/fapi-policy-or-nv-read-write.fint (exit status: 99)
ERROR: test/integration/fapi-second-provisioning
ERROR test/integration/fapi-second-provisioning.fint (exit status: 99)
ERROR: test/integration/fapi-provisioning-error
ERROR test/integration/fapi-provisioning-error.fint (exit status: 99)
ERROR: test/integration/fapi-info
ERROR test/integration/fapi-info.fint (exit status: 99)
ERROR: test/integration/fapi-unseal
ERROR test/integration/fapi-unseal.fint (exit status: 99)
ERROR: test/integration/fapi-unseal-persistent
ERROR test/integration/fapi-unseal-persistent.fint (exit status: 99)
Analysis:
All unit tests pass.
I think, by reading up, that the failures I get in the esys integration tests are normal.
I raised an issue on github, to check with the experts.
There are a 4 failures in the fapi integration tests.
Then, there are a number of errors. But those are because the last failing test leaves the TPM in a status that's not ok for the next tests.
this image is edited, I removed passing tests inbetween
For reference, this is how a test looks like when I force the TPM to be unavailable by pressing the reset on the EVM (I skipped optional tests here, that's why the total count is lower):
results when the TPM IC is deliberately disabled, unit test, integration, mandatory
Then, after restarting the device, everything is back operational.
results when the TPM IC is re-enabled, unit test, integration, mandatory
tpm2-abrmd: running integration test
As with the tpm2-tss package, I'm running the tests on the real hardware TPM chip.
Configure and execute
sudo ./configure --with-dbuspolicydir=/etc/dbus-1/system.d --with-systemdsystemunitdir=/lib/systemd/system --with-systemdpresetdir=/lib/systemd/system-preset --datarootdir=/usr/share --enable-unit --enable-integration --enable-test-hwtpm
sudo make check
Test log:
Fullscreen test-suite_tss_abrmd_202112112344.log Download
   tpm2-abrmd 2.4.0-20-g41fd797: ./test-suite.log
# TOTAL: 47
# PASS:  26
# SKIP:  0
# XFAIL: 1
# FAIL:  20
# XPASS: 0
# ERROR: 0
FAIL: test/integration/auth-session-max
Invalid TABRMD_TCTI, got: "" see --help.
FAIL test/integration/auth-session-max.int (exit status: 1)
FAIL: test/integration/auth-session-start-flush
FAIL test/integration/auth-session-start-flush.int (exit status: 1)
FAIL: test/integration/auth-session-start-save
FAIL test/integration/auth-session-start-save.int (exit status: 1)
FAIL: test/integration/auth-session-start-save-load
FAIL test/integration/auth-session-start-save-load.int (exit status: 1)
FAIL: test/integration/max-transient-upperbound
FAIL test/integration/max-transient-upperbound.int (exit status: 1)
FAIL: test/integration/get-capability-handles-transient
FAIL test/integration/get-capability-handles-transient.int (exit status: 1)
FAIL: test/integration/manage-transient-keys
FAIL test/integration/manage-transient-keys.int (exit status: 1)
FAIL: test/integration/session-gap
FAIL test/integration/session-gap.int (exit status: 1)
FAIL: test/integration/session-load-from-closed-connection
FAIL test/integration/session-load-from-closed-connection.int (exit status: 1)
FAIL: test/integration/session-load-from-closed-connections-lru
FAIL test/integration/session-load-from-closed-connections-lru.int (exit status: 1)
FAIL: test/integration/session-load-from-open-connection
FAIL test/integration/session-load-from-open-connection.int (exit status: 1)
XFAIL: test/integration/start-auth-session
XFAIL test/integration/start-auth-session.int (exit status: 1)
FAIL: test/integration/tcti-cancel
FAIL test/integration/tcti-cancel.int (exit status: 1)
FAIL: test/integration/tcti-connections-max
FAIL test/integration/tcti-connections-max.int (exit status: 1)
FAIL: test/integration/tcti-double-finalize
FAIL test/integration/tcti-double-finalize.int (exit status: 1)
FAIL: test/integration/tcti-set-locality
FAIL test/integration/tcti-set-locality.int (exit status: 1)
FAIL: test/integration/hash-sequence
FAIL test/integration/hash-sequence.int (exit status: 1)
FAIL: test/integration/not-enough-handles-for-command
FAIL test/integration/not-enough-handles-for-command.int (exit status: 1)
FAIL: test/integration/password-authorization
FAIL test/integration/password-authorization.int (exit status: 1)
FAIL: test/integration/tpm2-command-flush-no-handle
FAIL test/integration/tpm2-command-flush-no-handle.int (exit status: 1)
FAIL: test/integration/util-buf-max-upper-bound
FAIL test/integration/util-buf-max-upper-bound.int (exit status: 1)
Results:
Analyse:
I don't know what's the cause of the failures. I tested with and without the tpm2-abrmd.service running.
tpm2-tss-engine: running unit and integration tests
This one has unit tests similar to tpm2-tss.
When the Access Broker and Resource Manager service is running, there's no access to the raw device. It's in use.
The tests accec the raw character device, so service needs to be stopped before the integration tests.
Build and run test suite
sudo ./configure --enable-debug --enable-integration --enable-unit --with-device=/dev/tpm0
sudo systemctl stop tpm2-abrmd.service
sudo make check
sudo systemctl start tpm2-abrmd.service
Results:
Analysis
 WIP
