Industrial Automation
Forum Timer choice and circuit design for instrument automation
  • Answers 3 answers
  • Subscribers 291 subscribers
  • Views 1865 views
  • system timer
  • instrumentation & automation
  • timer
  • solenoid valve
ghostofsolo
ghostofsolo over 8 years ago
Hello, I need some help choosing the appropriate timer(s) for an instrument I am attempting to design. I am not a control engineer, and I'm learning electronics, so I know just enough to be dangerous. I'm currently more into tweaking existing designs.
I need to control three solenoids over a 24-hour period every three days. Every three days, I need to open a solenoid at 0:00 and close at 8:00; the second opens at 8:00 and closes at 16:00, and the third opens at 16:00 and closes at 23:59 (or at 0:00 the next day). I need the timer to be easy to use and re-program by a user in the field, most likely just changing days of operation since the time periods are static.
I was thinking along the lines of using one of the timers on this page:
http://www.newark.com/w/c/automatio...el-instrumentation/prl/results?st=time+switch
I have experience with the Omron  H5S-WB2H5S-WB2 but it only controls two channels I could install two of these and take care of it that way
Or is there a circuit that could incorporate a single-channel timer?
  • shivk67
    0 shivk67 over 8 years ago
    Timer circuits used to provide time delays for triggering, Types of timer ... Design and Implementation of GSM Based Industrial Automation. Simple List EIE Projects for Electronics and Instrumentation Engineering Students ... A jumper sets the option In this circuit design we used an AT80C52 microcontroller which length of the period can be configured by making suitable changes to the microcontroller’s source code.
    For more detail visit here:- Industrial automation training in lucknow
  • ghostofsolo
    0 ghostofsolo over 8 years ago
    Both of these solutions sound appealing; one for simplicity of setup, the other for educational purposes.
    I've been curious about the Arduino for some time now.  If it can do things like incorporate sensors as well as timing, all the better.
  • rsc
    0 rsc over 8 years ago
    Sounds like you are looking for something like a 3-zone irrigation/sprinkler timer.  There are many on the web for around $50.
    Of course, that's not as fun as making one yourself.
    Scott
    • Vote Up +5 Vote Down
    0 genebren over 8 years ago
    Randy,
    This might be an excellent opportunity to use something like an Arduino as a learning project.  You could likely instrument something using the Ardunio and a relay board for far less than the cost of one or more controllers.  The programming should not be too complex and it might open some new doors for you in your electronics education.
    Gene
