Industrial Automation
Forum 4-20mA Input To Microcontroller
  • Subscribers 285 subscribers
  • Views 2946 views
  • industrial
  • 4-20mA
  • industrial automation
meera_hussien
meera_hussien over 2 years ago
What is the best practice to create a 4-20mA input that can be feed in to microcontroller ADC pin?
  • meera_hussien
    0 meera_hussien over 2 years ago in reply to robogary
    Thanks robogary .
  • meera_hussien
    0 meera_hussien over 2 years ago in reply to Steve524
    Thanks for the info Steve524
  • meera_hussien
    0 meera_hussien over 2 years ago in reply to michaelkellett
    Thanks for the info michaelkellett . I will look into the details.
  • robogary
    0 robogary over 2 years ago
    A 500 ohm resistor across the 4-20mA creates a 2-10v input. 250 ohm for 1-5v input. Use code to check for a value below 1 or 2v (open).
    If the signal is bipolar, 6v becomes zero, 10v full scale, 2v full scale negative.
    The commons need to be tied together.
  • Steve524
    0 Steve524 over 2 years ago
    This may work for you :Current to Voltage Converter Module 0/4-20mA to 0-3.3V 0-5V 0-10V Voltage Transmitter Signal Conversion Conditioning Board
    www.amazon.com/.../B0BL3YM7RM
    0 michaelkellett over 2 years ago
    You need to read up on 4-20mA interfacing - lots of stuff on the web.
    There are many ways to make a 4-20mA input to a micro - it's often simpler simpler to use an external ADC combined with the 4-20mA receiver.
    But you want to use the ADC on your micro:
    It can be done with basic op amps and passive components but I can't suggest a design with out knowing  a LOT more about your application.
    There are 4-20mA receiver chips like the TI RCV420 and I suggest you look at these.
    Mouser have them in stock but they are not cheap (£8.20 each).
