Industrial Automation
Forum Relay question
  • Subscribers 290 subscribers
  • Views 801 views
Relay question
apostrophe
apostrophe over 8 years ago
Hi
Same project as the feed through terminal blocks...
I have a 12V DC water pump that I wish to turn on and off using a relay that can be DIN rail mounted, the pump draws a maximum of 15A.  I only have 12V DC available to power the pump and switch the relay.
I was going to use the following relay https://www.phoenixcontact.com/online/portal/no?uri=pxc-oc-itemdetail:pid=2961309&library=noen&tab=1 but was wondering if there are any others available that people have experience with that could be recommended
Dave
    jw0752 over 8 years ago
    Hi David,
    The relay that you show is rated at 16A and the Pump draws 15A. This may be too close a rating for an inductive load like a motor. While it will work for a while it would be better if you can find a relay with 20A or 25A contacts. If you can't find anything in electronic suppliers check out automotive where relays run on 12 volts and routinely handle higher amperage.
  • 2face
    2face over 8 years ago
    Hi David,
    Can you please put the link to the project here?
