Internet of Things
Internet of Things
Forum I need help in flashing CircuitPython in nRF52840 DK can anyone help me out
  • Replies 19 replies
  • Subscribers 516 subscribers
  • Views 3655 views
  • circuitpython
  • nRF528420
manojroy123
manojroy123 over 2 years ago
I need help in flashing CircuitPython in nRF52840 DK can anyone help me out. I tried nrf tool but it shown a lot of error. Is there any other way to flash CircuitPython in the development board.
  • mp2100
    mp2100 over 2 years ago in reply to manojroy123 +2
    I am confused by this screen shot. The headline says circuitpython and nrf52840. But your windows folder says micropython. Thats different from circuitpython. And it says esp32s3, not nrf52840. Ok. You…
  • aswinvenu
    aswinvenu over 2 years ago in reply to manojroy123
    Nope it's not the bootloader. It's a uf2 image of circuitpython. You need uf2-bootloader in-order to run that application
    The flow is as follows
    resetHandler -> UF2_Bootloader -> Circuit Python image (*.uf2)
  • manojroy123
    manojroy123 over 2 years ago in reply to aswinvenu
    I tried nrfprog it is showing error. Can you help me in solving that error given above
  • aswinvenu
    I am not a windows user! Dont know how to help you with that. But I would strongly recommend you to do the following things
    1) Unistall the nRF Command Line Tools
    2) Check which version of windows OS you are using (32/64)
    3) Download the nRF Command Line Tools by checking the correct OS version
    4) Install the nRF Command Line Tools
  • manojroy123
    ok
  • manojroy123
    Still getting same error with nrfjprog. What is the process to install it. I tried in fresh windows.
    shabaz over 2 years ago in reply to manojroy123
    Your error message suggests a DLL failed to load. This appears to be an issue with your tools installation. You could try another board, but it doesn't sound like a board issue.
    If you've followed the install instructions to the letter, and it doesn't work, it's worth raising a problem report with the developers.
  • mp2100
    I am confused by this screen shot. The headline says circuitpython and nrf52840. But your windows folder says micropython. Thats different from circuitpython. And it says esp32s3, not nrf52840. Ok. You can name your dir anything you want. But it confuses me.
  • manojroy123
    manojroy123 over 2 years ago in reply to shabaz
    Do you have link that can help me in proper installation of nRF-commandline-tool
    Unfortunately no. You should try to follow any official instructions. If that doesn't work, discuss with the owner (for instance, if it is on GitHub, you can raise an issue). If it is on a manufacturer download page, then raise an issue with their tech support (or their discussion forum, since they may know what the issue is).
    Also, there seems to be some issue with the screenshot, a discrepancy regarding MicroPython and ESP32, compared to what would be expected (see the comment from mp2100 above).
