Internet of Things
Internet of Things
Forum Home appliances causing 60 fires a week in the UK.. ideas to reduce the risk
  • Replies 26 replies
  • Subscribers 522 subscribers
  • Views 3514 views
  • fire-alarm
  • tumble dryer
  • home_appliance
  • home iot applications
  • fire alarm
  • home_appliances
  • washing_machine
  • fire
shabaz
shabaz over 8 years ago
Posting in IoT for lack of a better section.. and solutions or monitoring of home appliances may use IoT.
I was quite surprised to see this statistic : (
Faulty appliances 'cause 60 fires a week' - BBC News
It seems a huge number. Apparently this is mainly due to washing machines and tumble dryers. The following article discusses what causes the fires for tumble dryers, and how to reduce the risk of it:
https://www.manchestereveningnews.co.uk/news/greater-manchester-news/five-rules-stop-your-tumble-14112798
I've never had a tumble dryer (I use a clothes line if it isn't raining) so I can't be sure, but reading through that article, it seems the procedure to reduce the risk is really onerous. The article suggests vacuuming around the dryer and fluff can accumulate at the rear of the dryer. I can't imagine many people moving a dryer to vacuum behind it frequently, because of the weight of it, and presumably some are integrated (bolted) into position. This video only discusses how to clean fluff from the front filter, which looks easy enough: https://www.youtube.com/watch?v=rQruzikHdQI  but it doesn't address the other areas that may need to be regularly inspected and cleaned.
The article also discusses that tumble dryers should not be operated at night when people are asleep, or when no one is at home. To me, that seems like the lowest-hanging technical workaround until tumble dryers can be made safer; retro-fitting them for free, with a lockout system that will prevent operation unless light and motion (i.e. occupancy with activity) can be sensed - perhaps by Bluetooth. If either light or motion is not sensed for longer than (say) ten minutes then the dryer could be powered down. A fire alarm should also be fitted for free if one is not already fitted. Anything less seems unreasonable, considering tumble dryer manufacturers must know their machines pose such a high risk.
How do other people manage the risk? I would trust myself not to use a tumble dryer in the evening, but what if someone fell asleep on the sofa during the daytime and no-one else was at home. Or teenagers. Can they really be trusted to avoid using a tumble dryer at night, and adhering to the no house-parties rules : ) when parents are traveling?
And on another note.. it will be likely country-specific, but it would be good to hear advice on fitting fire alarms in locations where washing machines and tumble dryers will be fitted - e.g. what type of alarm, what distance is recommended, etc, from those who are experienced in this area. It would be valuable information to a lot of people.
    mcb1 over 8 years ago +4
    it seems the procedure to reduce the risk is really onerous. The article suggests vacuuming around the dryer and fluff can accumulate at the rear of the dryer. Many older style dryers don't vent outside…
  • phoenixcomm
    phoenixcomm over 8 years ago +4
    For Sure RTFM. BUT folks today don't read them, So here's what I propose in order. 1. Color Action Comic 2. Instructional Video on DVD 3. Same as #1 and #2 but on a flash drive. 4. None of the above as…
    shabaz over 8 years ago in reply to mcb1 +4
    Ah, I didn't realise they were light. The machine in the video appears to have some labels near the opening, but I guess some people won't make the connection that following these are critical to safety…
    mcb1 over 8 years ago in reply to shabaz
    Apparently you can lead the horse to water, but can't make it drink image
    Education is the only way it will get resolved. Manuals aren't read or are forgotten after a short time.
    We have a campain regarding smoke alarms, but still people don't change the batteries.
    Q. how many of you have checked your RCD ... regardless if it's switchboard mounted or a plugin.?
    I suspect the answer is "never" because everything encourages people to stay away from consumer units/switchboards, and the culture is to only call an electrician to check things, when there is a fault. So no-one ends up going near consumer units for years perhaps, apart from the electricity guy who comes around to read the meter from time to time.
    Manual checks are expensive too, I don't know what an engineer would charge to come around and perform the tests for (say) the elderly who might not even be able to get at the consumer unit easily.
    I'm guilty of not checking ours monthly ... image
    It's a simple pushbutton, but the downside is it takes out the power, and while I've split mine, rebooting several PC's sisn't my idea of a fun afternoon.
  • e14phil
    e14phil over 8 years ago in reply to mcb1
    We have a combined washer dryer and i'm certain mine doesn't have a lint trap. The water drains outside but no vent for air.  Do they all?
    mcb1 over 8 years ago in reply to e14phil
    Do they all?
    I've only come across one combined unit ... briefly, so I'm not sure.
    Some of the standalone models had an external vent, which connected to a 100mm? flexible pipe.
    I guess when you're drying clothes you'll discover where all the air goes ... image or the alternative is download the manuals ... image
    (Installation and User)
    Our's simply blows it out the front door. It has a plastic semi angled arrangement so you can rotate it to direct the air ... somewhere else.
    On the inside is a fine mesh like disc that unclips. Often this becomes about 5-6mm thick due to the build-up.
  • 14rhb
    14rhb over 8 years ago
    Shabaz,
    You've started an interesting and worthy discussion here. Our tumble gets the two door filters cleaned of lint every use as they are easily accessible. Occasionally I have pulled the unit out from under the worktop and again hoovered lint out of the 4" output duct. What did surprise me was that a few years ago I did open the case up and found some lint had gathered internally in areas that you wouldn't imagine.....you have reminded me to do that again. Maybe I should try and get some photos to share on here.
    There is some good advice here from the E14 community and the links about ameliorating the risks. I know someone who actually has their tumble drier outside (under cover).
    I would think that lint build-up would be the main cause of fires in tumble driers and/or combined with simple component or wiring failure. When that happens we are essentially past the usefulness of thermal cut outs and probably MCBs on the electrical distribution. Therefore highest priority is to reduce that lint build up. Manufacturer's could take a better approach to mechanical design to mitigate against leakage of particles into the heater box. Suitable IP rated internal enclosures could provide additional protection to lint ingress around cables and connectors for high current). I am however amazed at the photos that show them burning so fiercely - I bet you'd find it hard to light one on purpose with a match !
    As mentioned by shabaz they do also need more sensors.
    There are two sensors I can think of that should be mandated in the legal specifications for all countries (with an indicator to show this is why the machine isn't working):
                 (1)     Optical sensor(s) in high risk areas of the machine - namely around the heater and high current wiring to detect lint not smoke.
    AND      (2)     An optical particulate measurement in the hot airflow - which cuts out should that count of particles get too high.
    I guess we all want to know why manufacturers haven't done this so far.....and I guess the answer is that we want cheap goods. Correct me if I'm wrong, but most of the makes listed in the news article seem to be at the lower end of the price range.
    I look forward to reading more on this thread and as mentioned I will try and add some photos from my tumble drier.
    Rod
  • 14rhb
    14rhb over 8 years ago in reply to mcb1
    I was unsure where the air went after being condensed inside those units...so I Googled it and found this What is a Condenser Tumble Dryer and how does it work?
    The article states that the air is recirculated, which makes sense as that would be most efficient, and that the lint collects in the condenser water. So if the condensing tumble is plumbed into a drain you likely won't even notice this. The amount I get in a non-condensing tumble's filter would easily be noticeable if it was in a sump of condenser water.
    This could start a whole new debate given the recent findings of manmade fibres entering the oceans from washing machines !
    Rod
    shabaz over 8 years ago in reply to 14rhb
    Hi Rod,
    That's really interesting information. It is worrying that the lint gets right into the machines since not everyone can open them up. It would be awesome to see photos when you do open your machine next time.
    You're right, Whirlpool seems to be the offender according to that report for certain fires, i.e. their Hotpoint/Indesit/Creda brands which are built down to a cost.
    It's all a very unfortunate combination - heater, lint, air, and no easy way of monitoring/inspecting, if there are a lack of sensors fitted.
    Maybe another mode is damp/conductive lint near motor brushes too, igniting and then all other dry dust and lint will just stoke the fire immensely : (
  • 14rhb
    14rhb over 8 years ago in reply to shabaz
    Hi Shabaz,
    You also know that there is also a catch-22 for anyone who decides to service their own machine; any fire and the insurance company/manufacturer's could try and claim no responsibility if they can proove it could have be due to a negligent service !
    So although that is a minor dilema for us techy types, as you have mentioned, many folk cannot get to do their own service for numerous reasons. You are quite right - a robust fail safe solution is needed.
    [Might need to alias myself when posting those photos inside my tumble  image ]
    Rod
  • e14phil
    e14phil over 8 years ago in reply to 14rhb
    Looks like mine condenses the liquid and pumps it out with the waste water. Fancy!
