Medical
Medical
Forum CR1632 (3v) vs. Two AA's
Join Medical to participate - click to join for free!
  • Subscribers 16 subscribers
  • Views 1533 views
  • cr1632
  • capactity
  • frontpage
  • aa
  • battery
Hey,
Kind of a newbie at this, so forgive me if this is a stupid question, but if I've got a small lifeline alert pendant transmitter that normally runs on a CR1632, can I replace it with two AA's?  Are there any disadvantages? Do CR batteries last longer, have more capacity than AA's?
On a separate note, if I want to replace the batteries with a power supply, can I use a 5v USB supply or would I have to look for a 3v supply?
Howie
  • clem57
    clem57 over 11 years ago +1
    Panasonic CR1632 3V/120mAh High-Energy Lithium Battery vs. 2 AA's. Read Batteries and cell characteristics - Do It Easy With ScienceProg which explains how batteries are measured... Clem
  • clem57
    0 clem57 over 11 years ago
    PanasonicRegistered CR1632 3V/120mAh High-Energy Lithium Battery vs. 2 AA's.
    Clem
    0 michaelkellett over 11 years ago
    Why do you want to do this - the pendant's case can't have room inside for 2 x AA batteries so you'll end up with a much bigger device - with an external supply it would have wires as well.
    You should assume that it needs the correct supply voltage of 3V.
    For something safety critical like a lifeline alert you should not modify it unless you know very well what you are doing and also have the facilities to test the modified device properly.
