Motors and Drives
Motors and Drives
Clem's CNC Control Project Clem‘s numerical control – or how I learned to dig through a pile of parts. Introducing the project.
Join Motors and Drives to participate - click to join for free!
  • Author Author: mayermakes
  • Date Created: 3 Aug 2022 9:49 AM Date Created
  • Views 1420 views
  • Likes 9 likes
  • bldc
  • linuxcnc
  • trinamic
  • cnc
  • motorcontrol
  • prototyping
  • marlin
  • stepper
  • machining
  • grbl
  • mayermakes
  • Actuators
mayermakes
mayermakes
3 Aug 2022
I‘m Clem , you may know me as one of the hosts of element14 presents.
What you may not know, is that for the longest time a project has been lingering in the background of my videos. It is a CNC mill, built form project leftovers and parts collected over the last few years. I planned to work on it in between projects, but the reality of prototyping and video production dictates that such side projects have to be put off most of the time.
But that is about to change.
{gallery}CNC introduction
4th Axis chuck
CCM Rails leftover from previous project
the current miserable state of the CNC
the base should house the electronics and cooling
the cnc is sized to perfectly fit this niche behind my laser cutter
My CNC project was always planned to be weird and different, but it slowly evolved into the idea of building a machine specifically for the machining needs of my little prototyping venture.
We are entering a CNC building Series that forces me to finally finish this project and gives me the opportunity to explore more cutting edge tech related to motor controls and power systems as well as
build and operate the tried and tested building blocks of common CNC machines for enthusiasts and home users.
I will blog about this project over the next several months on Element14.com and occasionally do quick clips on my socials (@mayermakes on all major the platforms).
So what are we (yes I need YOUR, input help, advise) going to do exactly?
  • Rebuild the CNC project from scratch utilizing parts I already have on hand and decide on additional parts to complete the project.
  • Explore the latest offerings in Motors, drivers and control systems to get a grasp on how they relate to the use case of a maker/prototyping business/product development.
  • Build the most basic versions out of commonly available and low budget parts and Control solutions.
    Wrap our findings up in custom built electronics. AKA manufacturing our own Electronics.
  • Compare the High End and Basic version in theory and practice. To learn where it is beneficial to cut cost or spend more on a better version.
  • Conceptualize alternative motion systems, Cooling and machining solutions (I‘m thinking of ECM- electro-chemical machining , the low tech brother of EDM- electric discharge machining).
  • Put all our findings together to form a working useful machine that hopefully inspires other people on the element14 community to build their own fabrication machines specifically for their use cases.
We will start our journey in my next post with an analysis of the status quo.
Go over parts that are already part of the project and some of their pros and cons.
Make sure to post your Ideas and Feedback in the comments so I can incorporate them in the project, of course I’m also happy to answer any questions you might have related to CNCs or similar machines as far as my knowledge reaches!
This blog is a part of Clem's CNC Control Project.  Click the Next button to the right to go to the next blog.
    DAB over 4 years ago +1
    Good idea, I look forward to the blogs.
  • davedarko
    davedarko over 4 years ago +1
    I'm fairly new to cnc/mill/lathe stuff, but heard about DRO (digital read-outs) and how you would want that on a lathe at least. Since we have a CNC at the space, but no mill - I want to have a handheld…
  • mayermakes
    mayermakes over 4 years ago in reply to davedarko
    that is actually a very good featuere request and I already plan to build that into the project! Quite often I would just like to make a hole at a specific point or mill a slot.
    going through the whole CNC cam process just for a little  alteration is pretty cumbersome. So yes DRO and a Pendant to activelly jog the mill are on the list! thanks for your Input!
  • davedarko
    I'm fairly new to cnc/mill/lathe stuff, but heard about DRO (digital read-outs) and how you would want that on a lathe at least. Since we have a CNC at the space, but no mill - I want to have a handheld controller for the CNC to use it as a mill without using any computer controls. That would be on my bucket list, if I'd build a CNC - DROs (if necessary) and handheld remote.
  • mayermakes
    We already have a little update before the next post.
    the machine will have a minimum of four movement Axis, X,Y,Z as in a classcal cartesian machine + A as arotational axis, enabluign it to be used as a CNC lathe and for 4 axis machining.
    The 4th axis will utilize two motorized lathe chucks I already have, which means we need to learn about dual wielding /syncronizing two axis.
    Let me know some weird features you 'd like to see!
