Motors and Drives
Motors and Drives
Forum How can I connect a drill bit, etc. to my stepper motor?
Join Motors and Drives to participate - click to join for free!
  • Subscribers 76 subscribers
  • Views 2815 views
  • stepper_motor
  • motor
Hi there,
I've purchased a stepper motor and connected it to my Raspberry Pi and a driver. Now, my cylindrical smooth shaft will happily rotate as per my wishes, but I'm lost as to how to go about connecting this to drive anything.
The only thing I've tried is using a plastic gear to tightly fit on the smooth shaft, but the plastic gear came off when when trying to drive something needing a lot of torque.
Any suggestions would be greatly appreciated! I'm wondering if I can find parts on element14/newark to purchase.
Thanks!
  • bad_boy_y
    bad_boy_y over 13 years ago +1 verified
    if the motor shaft and your drill bit have the same size the easy way is to use a screw terminal like this and cut the plastic use one terminal like a shaft coupling. But if your shaft and bit have different…
  • bad_boy_y
    0 bad_boy_y over 13 years ago
    But if your shaft and bit have different size you need shaft coupling with different both end and right size.
    http://www.newark.com/red-lion/rpgfc002/flexible-coupling/dp/19P7166?in_merch=Popular
    Have Good Day!
    0 e14 Contributor over 13 years ago in reply to bad_boy_y
    Wow, thanks!
    I'm thinking of printing something custom so I'll make it the same size as my motor shaft.
    I had no idea that coupling could be that expensive! It looks like it'll be more expensive than the motor itself.
    Thanks again,
    Joseph
    0 dougw over 13 years ago in reply to e14 Contributor
    Hi Joseph,
    Shaft couplers don't need to be expensive. I see some for sale at $1.80.
    You could attach a drill chuck to a coupler if you want to use a drill bit although your stepper probably doesn't have as much torque as your drill. The chuck would allow any size shaft to mate to your motor.
    Doug
  • kirkstrandberg
    0 kirkstrandberg over 7 years ago
    Then a stepper should be your last option, as it uses more power.
    The motors in standard drills are pretty efficient. If you have 50W power on the drill bit, you need at least 50W power on the input. That's basic physics, there's no way around it.
    Or if what you're looking for is torque but less speed/power, then look for a geared down DC motor. That can produce the same torque but as you lower the rpm of the output you can lower the power input needed.
