Motors and Drives
Motors and Drives
Documents Planetary Gearheads
Join Motors and Drives to participate - click to join for free!
  • Author Author: rbennett
  • Date Created: 17 May 2010 12:40 PM Date Created
  • Last Updated Last Updated: 17 May 2010 2:24 PM
  • Views 992 views
Planetary Gearheads
Industrial - IP57 Seriesimage
The IP57 gear box is designed to provide long life in industrial automation, industrial, scientific and process control applications that require repetitive cycling featuring high dynamics, accurate velocity or positional control.
Advanced manufacturing techniques, combined with a design focused on the needs of state of the art motion control has resulted in a combination of optimised performance characteristics combined with economic prices.
  • Planetary construction for high torque and compact dimensions
  • Supplied complete with 6.35mm pinion
  • Suitable for use with either servo or stepper motors
  • Stainless steel output shaft
  • Height = 57.2mm, Width = 57.2mm
  • Plastic body cover
Body DiameterRatioPart NumberCheck Price
Gearheads
54mm5:1IP57-M01-5:1178-4794178-4794
68mm10:1IP57-M01-10:1178-4795178-4795
80mm50:1IP57-M01-50:1178-4796178-4796
Mounting Kits
400MAX00001FITTING KIT 1 - 5:1178-4797178-4797
400MAX00002
FITTING KIT 2 - 10:1178-4798178-4798
400MAX00003FITTING KIT 3 - 50:1178-4799178-4799
Data Sheet
  • compact_dimensions
  • gearheads
  • with_pinion
  • planetary
  • gearbox
  • repetitive_cycling
  • high_torque
